Small problem with thermostat housing
Hello from Germany. New to the forums. I was replacing my thermostat and when I re-installed the housing I over torqued one of the bolts. This cracked the housing. I want to order another housing but here in Germany its better if you have the OEM part number. This is not easy for me to find. Does anyone have that P/N?? Its the part with the coolant filler neck and coolant filler cap which houses the thermostat in the block.
I can try at the Chrysler dealer and also if the motor is the same as the Eclipse motor I can try at the Mitsubishi dealer. Either P/N will help.
Thanks for reading and thanks in advance for any help obtaining this P/N.
RE: Small problem with thermostat housing
Chrysler will have the part and so will Mitsubishi (Mitsu, here in the states though). I don't know if Mitsu overseas will have the 420a motor's parts since the 420a equiped Eclipse wasn't introduced overseas....or was it?
I don't have part numbers though. If you can't get it in Germany, you can get it from this site... http://64.15.251.33/cgi-bin/sewse?/u...p2+%22*%22+DAP
I've ordered stuff from there before and they came fairly quick for Hawaii standards.
