1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
wierd
Old Oct 26, 2006 | 03:59 AM
95_Avenger's Avatar
95_Avenger
Default wierd
ok so i have been having car problems for the last mounth and finaily had a dealership dude come look at my car. i showed him the little computer test thing and he said i dont need that and turned the car on and then off three times then back on and the batt light flashed some code i neva heard of this...
Old Oct 26, 2006 | 04:22 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: wierd
That is called the keydance. 95-97 had that convenience, but the 98-00 did not. You turn the key to the "On" position 3 times...then off 2 times, on the third time to "On", you leave the key in the "On" position and count the CEL light flashes. They flash in pairs btw.
It may help if you count seconds while turning...I used to count to 3
1 second...2 seconds...3 seconds...stop. See, easy.
Old Oct 26, 2006 | 04:30 AM
95_Avenger's Avatar
95_Avenger
Default RE: wierd
i thought it was wierd just by doing that he told me my fuel pump went out i was shocked!!
Old Oct 27, 2006 | 12:47 AM
slhomer's Avatar
slhomer
Default RE: wierd
The Key dance is cool I learned that from one of SilverCoupe's post's. I have found this forum is a wealth if information.
Some day Ill have a hot Venger if my daughter doent take from me first and make me buy a 3000GT lol
(If my wife will let me buy one)
Sean
Old Oct 28, 2006 | 05:20 PM
95_Avenger's Avatar
95_Avenger
Default RE: wierd
o was wandering what code 41 of the key dance is any body know??
Old Oct 30, 2006 | 08:14 AM
95_Avenger's Avatar
95_Avenger
Default RE: wierd
to the top!!
Old Oct 30, 2006 | 08:21 AM
silvercoupe97
Uber Moderator
Default RE: wierd
Are you having charging problems? That's what 41 means, there's an issue with the alternator field control circuit. That includes the alternator, pcm, asd relay, battery light in the cluster. Is your battery light on? Does the interior lighting come on? Is your headlight dim (and not because of it being fogged up)?
Old Oct 30, 2006 | 10:49 AM
95_Avenger's Avatar
95_Avenger
Default RE: wierd
yea they are dim and yea the inteir lightin comes on.
Old Oct 30, 2006 | 11:05 AM
silvercoupe97
Uber Moderator
Default RE: wierd
Have your alternator checked for amperage and voltage. Check the fusible links in the fusebox that are for the alternator and battery. You need to check them physically and electrically. Make sure that both the bat and alt links have the same voltage with the car off and on. The two links are always on btw. I forgot to add that the battery is also in the charging circuit. So, if the battery dying, that can have an affect on the charging system too. Worse case scenerio, the pcm is not allowing the alt to charge the battery, then the alternator, everything else is easy and not as pricey.
The question remains though, is your battery light on? Let the car do a self check for all your cluster lights by turning the key to the "on" position and wait for the battery light to turn off. If it doesn't come on, you'll need to check the bulb because it's in the self test.
Also get a Haynes/Chiltons manual
Old Oct 30, 2006 | 11:07 AM
silvercoupe97
Uber Moderator
Default RE: wierd
Also, I take it you're having an issue with this code.
If you need some online help, you're going to have to give us some info, otherwise we're just tossing things at you.
