1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
headlight mounting hardware
Old Nov 21, 2006 | 12:36 AM
jp_greenville13's Avatar
jp_greenville13
Default headlight mounting hardware
who has had problems with headlight hardware? u know who u r. what were ur solutions.
Old Nov 21, 2006 | 03:20 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: headlight mounting hardware
Are you talking about the tabs?
Old Nov 21, 2006 | 10:48 PM
jp_greenville13
no the bolts in the back. the threaded brass insert that is molded into the plastic stripped out and i cant drive my car till i find a solution.
Old Nov 21, 2006 | 11:00 PM
99_avenger's Avatar
99_avenger
yeah same happend to me i just got new headlight
Old Nov 22, 2006 | 02:24 AM
silvercoupe97
Uber Moderator
You can always put a dab of plastic weld or JB weld in the holes, if you still have the brass inserts, carefully put the inserts back in and wait 24hrs, and voila, like new again....sort of, lol. I'm assuming that the brass inserts are still there. You can thread in a screw and pull it out by the screw head..well, not a screw, but a bolt
Old Nov 22, 2006 | 08:27 PM
jp_greenville13
thats exaclty what i did. minus the brass inserts. they had thread bodies stuck in them and i didnt want to wait to take them out. instead i used plastic weld with drywall anchors and self tapping screws.
