Hey Yo Slhomer
I have a 96 ES 2.5
As for mod's I have only lowered it sofar.
Next is Tranny rebuild before i start on the motor (I dont want to blow the tranny with to much torque)
I have only had it about 6 months and the day after I bought it I had it tuned up tranny flushed and oil change done.
I also replaced the headlights, both O2 sensors because of CEL, and rear bering assemblies and crank sensor.
The car has ran great sence I bought it, The CEL came on after about 3 weeks it was the upper that errored but i figured why not replace both
The only time it ever died on me was when the crank sensor went out but it was a quick fix.
I have been thinking about buying an extra 2.5 to play with and see what a few of my friends could do to it to get more power out of it.
Yo I preciate that cuz Im rollin n the same wip and I got the tune up oil/ and trans changed, uhhh master and slave cylinder changed and lines flushed, lower balljoint and CV Shaft, new rim, and now my rear suspension is making noise. But now I have a better idea what to do next on my wip along with the timing belt and oil change.
Autostick is that a custom job. I got this cat @ work who said he had that on his Eclips I said they samethin hi ho silver up there said to the guy and he said that he has P,R,N,D then 1-5 also.
ORIGINAL: silvercoupe97
Autostick? Do you mean just auto? 6 speed? I don't think these cars had the option of autostick, in any year or trim, not to mention having a 6 speed.
I will post a picture...and you tell me you don't see an autostick.
And yes, there is a difference between autostick and slapstick if that's what you're referring to...
Well then hook it up homie![8D]
But my boy up RI has this SUV I think its a Santa Fe but on his wip he has P,R,N,D then next to Drive there is is plus and minus is it like that?
Trending Topics
silvercoupe97
http://www.dodgeintrepidchat.net/php...mp;image_id=52
What do you see right before the CD player?
Column shifter?! OH WAIT - That should be on the steering column!!
Slapstick?! NOO - That only moves forward, back, and side to side...
Gee, I guess that since the first two of the three is ruled out, it's autostik!!
And no, Why should I hook a "homie" up?
I would show the rest of the car and modifications...but I don't want questions and people stating "You can't do that! There's no company that mass-produces it!!"
I meant hook me up with a pic. I must have bad eyes or sumtin but that looks like a regular shifter 2 me with auto drive button on it and 3 words or symbols that I can't see all to well. Sum1 help me to understand that pic.
I thought it b sumtin like a stratus my uncle had that had P,R,N,D then 2-4 or 2-5 on the shifter. Or like that Santa Fe I mention earlier.
ORIGINAL: PappiDread6
The button on the side is to turn on/off the overdrive.
Here's the track as follows :
PARK
REVERSE
NEUTRAL
DRIVE
SECOND GEAR
LOW
This network is slower in packet transfer than dichat...
