1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
E brake
Old Dec 25, 2006 | 08:55 AM
95_Avenger's Avatar
95_Avenger
Default E brake
ok so my brake light stays on what would cause this?? when i pull it up it work. i dont know what else to say execpt that the light just stays on.
Old Dec 25, 2006 | 09:19 AM
Goose's Avatar
Goose
Default RE: E brake
Had the same problem years ago. It was caused because my e-brake line was seized up by road salt, and the light never went off till i took it in to get looked at, it ended up costing me several hudred coin to get the brakes fixed. So my advice is to get it looked at now, and dont be a moron like i was!
Old Dec 25, 2006 | 11:05 PM
95_Avenger's Avatar
95_Avenger
Default RE: E brake
what all did you have to replace im buyin pads and roters tommorow.
Old Dec 25, 2006 | 11:31 PM
BuckNut09's Avatar
BuckNut09
Default RE: E brake
hey my ebrake is worthless honestly you could drive with it on and not make a difference my question is what i should check for b4 gettin it looked at by someone cus it isnt doin ne thing as of now
Old Dec 26, 2006 | 12:57 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: E brake
If you can drive with it on and not feel it, you most likely need to have the pads changed.
Any component of the brake system will cause the light to come on guys. You can easily check the fluid and the pads. Make sure that the e-brake is fully released because driving with it on doesn't help.
Old Dec 26, 2006 | 02:25 AM
airman's Avatar
airman
Default RE: E brake
my e brake light comes on when it's cold out before the engine warms up. don't know why. i ignore it.
Old Dec 26, 2006 | 11:17 AM
Goose's Avatar
Goose
Default RE: E brake
i drove with ny light on so long i had to replace everything to do with the brakes, and was told not to use my e-brake anymore because it was not worth fixing.
Old Dec 26, 2006 | 01:51 PM
PappiDread6's Avatar
PappiDread6
Default RE: E brake
Yo I never had used my E-Brake b4 till I got this car, is it a problem when you can drive in reverse with it on and not feel anything?
Old Dec 26, 2006 | 02:29 PM
Goose's Avatar
Goose
Default RE: E brake
You might not feel anything while its on, reverse or not. I know I never felt mine, but i dont think its a really big deal.
[IMG]local://upfiles/51671/C0D00A7FB51942DA82B2142E76499EE8.jpg[/IMG]
Old Dec 26, 2006 | 09:17 PM
silvercoupe97
Uber Moderator
Default RE: E brake
The ebrake isn't designed to stop the car, it's more for grabbing a hold of the drum around it and holding it in place (like when parked). I don't know if some of you guys have ever seen the ebrake pads....but they aren't big (small surface area and thin).
Stop thinking about drifting guys...the stock ebrake is on the opposite end of the that spectrum.
Goose is correct, you may or you may not feel it while moving. I know that I can feel the ebrake release on my car...that's assuming that I left it applied before moving and at a slow speed, release the ebrake and you may feel it. If you can't there may not be enough there to hold the car in place (if you're a manual).
