car studdering
RE: car studdering
It could be a few things at the same time or some sort of combo really. The place to start is to clean out your intake tract, it's probably the cheapest route....seafoam/MCCC That, if done thoroughly and correctly, will clean out the plenum, piston top, chamber, injectors, possibly the EGR valve, fuel tank pump filter, fuel lines, and fuel filter (although it should just be changed out).
Granted, your car's stuttering may be in a different direction, but again, it's a good place to start.
Have you ever ran your car until you were "empty" of gas? I ask this because sediments in your fuel tank may have passed the fuel pump's filter and could be clogging the fuel system, but again, it could be anything.
