1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
420a-6g72 swap ??????
Old Jan 10, 2007 | 03:14 PM
99avenger420a's Avatar
99avenger420a
Default 420a-6g72 swap ??????
hey silvercoupe97 i am wondering if you guys up at exileracing could do a 420a-6g72 swap and how much it would cost for labor i live in st.louis and i am willing to commute to chicago for a couple of days to have the swap done. i appretiate the help and a speedy reply
Old Jan 11, 2007 | 05:49 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 420a-6g72 swap ??????
I don't work there bro. I live in Hawaii now, lol.
There really wouldn't be a problem to doing that swap, but there's "more" aftermarket parts for your 420a than the 6g72/6g73's parts and peices swap.
A turbo kit would quickly put you past the swap's HP.
Old Jan 11, 2007 | 02:28 PM
99avenger420a
ya but wouldnt you have rebuild the motor to run alot of boost????? did u used to work at exile and how much do u think it would cost to have that swap done ????????
Old Jan 12, 2007 | 03:02 PM
airman's Avatar
airman
the cost of a motor swap [parts and labor] will probably be about the same as it would cost you [maybe a little less] to rebuild your 420a and turbo it - the 6g72/3 swap is probably not worth it. a turbo for a 4g63 is roughly about 3 grand...and at most you'll probably only get 10psi with that kit. doesn't have an IC and is missing some stuff that the 4grand kit has.
i say you keep with your 420a, rebuild it [i.e. new gaskets/lower comp pistons] and turbo it.
Old Jan 12, 2007 | 05:07 PM
99avenger420a
well i can buy a turbo kit on ebay for $1000 that will run 25psi of boost supposedly but the only question i have is then what tranny to get cause i really want awd silvercoupe97 what kind of tranny u got????????
Old Mar 16, 2007 | 07:23 AM
silvercoupe97
Uber Moderator
ORIGINAL: 99avenger420a
You can't worry about how much boost a turbo can run just yet. You will need to rebuild your motor with forged internals to run that much boost and you will need a stiffer clutch or higher stall torque converter (depending on whether you have a manual or auto tranny). A good stock running motor can't do anymore than 10psi for the most part as Airman stated.
*wow, was this really two months ago?*
