1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
so i have a ticking noise
Old Feb 15, 2007 | 03:13 AM
josef15111's Avatar
josef15111
Default so i have a ticking noise
Ok like the title says i have a ticking noise coming from the lifters i am almost certain now. my question is.. What do i need to buy and reapir to make it stop? and how hard do you all say this will be? i just replaced my alternator and it was fun LOL. any ways the ticking is getting on my nerves so i needa fix now.. all help is apprechiated and thanx in advance guys...
Joe 95 es
2.5
Old Feb 15, 2007 | 11:41 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: so i have a ticking noise
You can replace the lifters or use synthetic oil (temp fix) like Mobil 1 or Royal Purple and the likes.
Old Feb 16, 2007 | 02:46 AM
josef15111's Avatar
josef15111
i am already and have been using mobil 1 fully synthetic for bout 5 months and how hard is it to replace the liffters? and do i just buy the liffters? i wanna do it my self i know i can just wanna know what will be involved... thanx john
Joe 2.5 es
Old Feb 16, 2007 | 07:23 AM
silvercoupe97
Uber Moderator
It's not really anything to dreadful, just a matter of taking off the valve covers (and everything above them) and then, you're there. Just have a torque wrence and the manual handy and ready to go. Don't forget to get new gaskets and spark plug tube seals, since you'll have to remove the valve covers, the plenum uses a metal one, so you won't have to worry about that one, just be careful taking it off and don't bend it.
If it were me though, I'd have everyting replaced since I'll be there and everything will have to be removed anyway...might as well replace with new stuff...then, poof, no more lifter tick
Old Feb 16, 2007 | 04:26 PM
josef15111's Avatar
josef15111
Ok silver i dont even think it is my lifters ticking anymore i am not hearing the nosie from my heads but i hear the nosie real loud when i put my ear right where my power steering resivor is. its not by the engine but by my passenger wheel.. and this is when the car is in park and just idling. its a lite thump sorda a loud tick maybe. what is around there that will cause that ticking noise? abs light is on could it be the abs pump thingie or is there something like that that will cause a ticking slash loud little thunk????
thanx for all the help again
Joe
Old Feb 17, 2007 | 12:06 AM
silvercoupe97
Uber Moderator
I think I know what you're talking about, mine was doing the same thing, but then it stopped all of a sudden.
If I remember correctly, there a solenoid or canister in front of the wheel well and just below the headlights. I forget what it was for...I want to say that it was EGR related, but to be honest with you I forgot
Let me see what I can find/remember and I'll get back to you.
I do believe that what you are saying is right though, because I can remember there being a "loud" ticking that came from that area. I don't think it to be the PS pump though. I don't remember..is the ABS control block on that side? I ask because I thought it was on the driver's side.
Anyway, let me see what I can find for you.
Old Feb 17, 2007 | 12:31 AM
josef15111's Avatar
josef15111
O sweet thanks silver... I have been hearing the nosie for some time now and it dont do it all the time just usually at idle and it dont really do it when you first start the car, just wanted to say thanx again and yes the abs is one the driver i saw it tonight i was just throwing up ideas of what it could be.
thanx
joe
Old Feb 19, 2007 | 11:03 PM
MoPaul's Avatar
MoPaul
i would think it is the evap solenoid. you can get a new one but there's a good chance the new one will do it as well. you can check it by leaving your gas cap a little loose. it won't make the noise but your check engine light will typically come on because it will not see a pressure drop.
Old Jan 7, 2010 | 07:58 PM
heyttsguy's Avatar
heyttsguy
yeah its the evap solenoid. my 97 does the same thing. anyone with a 99 in here? i heard the solenoids on those ones don't tick. i checked at the dealer today and the part numbers are different for the 97s and 99s. anyone know if they are interchangeable. if so, im putting a solenoid from a 99 in mine.
