1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
headlight conversion
Old Feb 24, 2007 | 05:02 AM
blackvenge34's Avatar
blackvenge34
Default headlight conversion
hi i have a 96 avenger and i was woundering what it would take to put 97-up headlights on my car i mean bodykit fenders and hood fit around it and the bolts look like they would line up any one do it let me know thanx
Old Feb 24, 2007 | 10:46 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: headlight conversion
The 95-96 and 97-00 headlights are different from each other. The fenders, hood, bolts are all the same...just the fascia is different.
Old Feb 26, 2007 | 03:02 AM
blackvenge34
is it possible to convert it and is it hard and cost alot
Old Feb 26, 2007 | 10:41 PM
silvercoupe97
Uber Moderator
It is possible to convert, Bryan. You'll just need the parts from a yard car or buy new parts.
Let me clarify, to convert to a 97+ look, you'll need the front fascia (bumper cover) and headlights...that's it for the front. The rear, you'll need 97+ trunk lid and spoiler (if you like the low profile spoiler), and rear fascia (rear bumper cover) and if you really want to complete the look, swap out the side badging with the 97+ badging...just the wording though, because the 97+ letters are extended into the door and fastened onto the door. The 95-96 letters use double sided tape.
Old Feb 27, 2007 | 12:06 AM
blackvenge34
i have the viper kit so is that the front bumper im sorry im not exactly sure what u mean by front fascia i just wanna do the front because i like the headlights and i wanna buy a pair but i guess the question is... is it worth it just for the headlights cuz mine are in pretty decent shap i got them from a seebring in the junkyard but i found headlights that come with hids on ebay and its about 300 all together give or take a dollar when u think bout it 200 for headlights and 200 for hid your saving 100 plus to buy a new set for my year its about 300-400 this is the link for the headlights with hid's.
^--click
Old Feb 27, 2007 | 12:17 AM
silvercoupe97
Uber Moderator
I believe the body kits are year specific too. So, if you get a 95-96 or 97+ kits, then you will need the corresponding headlights or your will see fitment issues.
That's a good price for the headlights and HIDs btw, although, they aren't going to be cutoff like projection HIDs, but they will provide better lighting. If you get these, make sure you point them down a good bit so as to not get the highbeam flash from oncoming cars.
Old Feb 27, 2007 | 01:36 PM
blackvenge34
i belive i got a kit that said 95-00 it was a urethane viper kit and most of the ones on ebay say 95-00 so does that mean i can get the headlights with no problem also it says that the hid system come preassemble to the headlight so does that mean i just plug them in and im good to go?
Old Feb 27, 2007 | 01:41 PM
blackvenge34
and those hids seem white i kind of want the blue look what if i bought new headlights and put those blue bulbs in them will i get a good light and the blue that i want or can u only get that from the hid's money isnt an issue what would you suggest?
Old Feb 27, 2007 | 08:45 PM
silvercoupe97
Uber Moderator
ORIGINAL: blackvenge34
You may just have to wait until the kit gets to you and do a fitment test.
Those HID kits are installed to replace the halogen bulb, which means that it's mounted and locked in like our halogen bulbs.
The blue replacement halogens give you an even lower visible light. I would suggest sticking Silverstarts or sticking with the HIDs and contacting the seller and see if they have bulbs in the 7000k-8000k range, those are in the blue light range.
Old Feb 27, 2007 | 09:00 PM
blackvenge34
the body kit i have had for almost a year its been on for a while it fit perfect and i'll ask about the diff bulbs
