1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
420a tranny question
Old Mar 15, 2007 | 04:28 PM
99avenger420a's Avatar
99avenger420a
Default 420a tranny question
is there a way to re-build your tranny so that you arent running so many rpms on the hwy ?
in other words is there a way to space out your gears ?
Old Mar 15, 2007 | 10:03 PM
MoparMJM's Avatar
MoparMJM
Default RE: 420a tranny question
auto or manual?
Old Mar 19, 2007 | 11:16 AM
99avenger420a
manual......
and i plan on turboing it after building the motor which is why i ask because now in 5th gear i can top out at 120mph but the car is really tryin hard after 110 at about 5000rpm's and with a turbo i will get there faster but i wont be able to go any faster
thanks for any advice
Old Mar 19, 2007 | 11:34 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
That's your speed limiter. I'm surprised that you even got up there. I know the V6 is governed at around 130. I don't remember if there was something to bypass that, but your tires are most likely H rated which is stable up to 130. Honestly, you don't even need to be at such a high speed. Build and boost your motor and put the speed on the tracks, not on our streets bud
Old Mar 19, 2007 | 05:20 PM
99avenger420a
no the thing is, is i want to time my turbo to spool at like 3000rpm but when im just daily driving on the highway im running at 3400rpm's at 80mph so i was wondering if there was a way that i coul get my gears "spaced out " so that i will have better accelaration and be able to cruise at 80mph pn the highway under 3000rpm's so that im not running on my turbo. DOES THAT MAKE SENSE ???????
thanks again for anny advice
