1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Hesitation and skipping at lower RPM
Old Mar 17, 2007 | 08:25 PM
spitfireflyr's Avatar
spitfireflyr
Default Hesitation and skipping at lower RPM
I just bougtht a 96 ES with a 2.5. The car had alot of miles, but it ran good and I need a car to drive back and forth to work (60 miles each way). So anyways I buy the car and drive away from the guys house, stop to get gas. When I pulled out of the gas station, the front flex blew and it started to skip and miss between 1800 and ~ 2500 rpm, and it idled very rough. I thought it was a vaccum leak, so I changed out the intake gasket.
Didn't help. So i figured out how to drive it, whenever i was going slow I would shift the overdrive off, this worked fine. Well the other night the temp changed from warmto very cool and started to rain,in the morning when I went out to start the car it wouldn't start. I figured it was moisture in the distributor cap. So I took the cap off and cleaned it. Still wouldn't start. Pulled the plugs and they were flooded. So I went and got new plugs, car started fine and runs like a dream now. Just wanted to pass on the information for anybody experiencing the same problems. Thanks to everyone here for all of the good information.
