1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Alternator capabilities...
Old Mar 24, 2007 | 06:54 PM
Nelson9937955's Avatar
Nelson9937955
Default Alternator capabilities...
I have a 2 channel amp that puts puts out about 480 watts RMS to two subwoofers. I want to get a 80 x 4, 4 channel amp to power some speakers. Is my alternator going to be able to handle this in my 98 Avenger SE? I just want to make sure I will be ok.
Old Mar 24, 2007 | 11:46 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alternator capabilities...
If you are a V6 then the alternator is 110 amps ..That will safely run 1000 watts with just an optima battery upgrade
Old Mar 25, 2007 | 01:45 AM
Nelson9937955
So I need a battery upgrade? Why would this be?
Old Mar 25, 2007 | 06:29 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
ORIGINAL: Nelson9937955
Because you need a fast draw/recharge capable battery. The normal off the shelf Duralast won't last and can't keep up.
I had the same issue back in the day and I upgraded to a gel cell and poof no more issues.
You can try it with your current setup, but it's guaranteed your headlights will start to dim along with the bass notes sooner than later.
Old Mar 25, 2007 | 12:16 PM
Nelson9937955
Can you give me a link to the exact battery I should get? Thanks alot guys
Old Mar 25, 2007 | 12:58 PM
bad venge's Avatar
bad venge
Section Moderator
Shop around locally ... The Optima are usually easist to find , but Stinger, Odessey and Batcaps are all good ones due to weight and shipping they are best bought locally ...
Old Mar 25, 2007 | 10:27 PM
Nelson9937955
Does autozone sell them? Do I need a redtop or yellowtop Optima?
Old Mar 26, 2007 | 12:22 AM
bad venge's Avatar
bad venge
Section Moderator
Autozone should sell them ...I prefer a redtop for primary starting/system purposes the yellow is good for just system use
Old Mar 26, 2007 | 12:36 AM
Nelson9937955
http://www.lowcostbatteries.com/optima-batteries.asp
So which one of these will fit and do you recommend? The cheapest model that will work, the better for me. I just want to get the model that I need and then I can shop around. Thanks again for all your help
I put in my car info and it said no products available for my car.
Old Mar 26, 2007 | 07:15 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.lowcostbatteries.com/product_p/75-25r.htm
thats what I have
