rear disc brake conversion
Old Mar 18, 2011 | 05:32 AM
89dakota318's Avatar
89dakota318
Default rear disc brake conversion
Just did a rear disc brake conversion on my 89 dakota. Went to junk yard and got rotors calipers and calper bracke along with proportion valve for total of 73$
Old Mar 18, 2011 | 11:35 AM
shadowthedakota's Avatar
shadowthedakota
nice...
Old Mar 18, 2011 | 10:27 PM
walkerman2188's Avatar
walkerman2188
could you tell how you did it this is sumthin i may look into 4 89 dakota 4x4 thanks
Old Mar 19, 2011 | 02:12 AM
Crazy4x4RT's Avatar
Crazy4x4RT
What type of vehicle did you get your parts? Shoot I'm braking down my rear axle soon I may do it too.
And post up pics!
Old Mar 19, 2011 | 04:59 PM
89dakota318
I used everything from a 97 jeep grand cherokee, I went to my local pullapart and found the jeep with good rotor , pads and calipers pullded the axels aout of it to get the backing plate( I used my factory axels) you will also need the jeeps proportion valve. You will need to make the center hole of the backeing plate a lil bit bigger I just went around it a few times with a dia grinder and after that it bolted up, had same bolt patter. After that I had to shorten my bake lines and hook up the jeeps flex lina along with finding a place to bolt down the flex line. I didn't use the parking brake so after all lines were hooked up everything went togeather like doing a regular brake job. This will only work for 5 lug but if you can find a car with a 6 lug rear rotor with same bolt pattern I'm sure you can get it to work
Old Mar 20, 2011 | 02:09 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Good idea! I guess for others with the 6 lug you could swap axle shafts to convert to the 5 lug. Where are the pics???
Old Mar 20, 2011 | 05:24 AM
89dakota318
I will have to pull the wheels back off tomorrw for some pics...
Old Mar 20, 2011 | 08:59 AM
siggie30's Avatar
siggie30
Did you replace the master cylinder as well?
Old Mar 20, 2011 | 12:57 PM
JDakota92's Avatar
JDakota92
Some of the newer 2nd gens had rear disc brakes
Old Mar 20, 2011 | 09:34 PM
89dakota318
I have a hole hydroboost system out of a 99 mustang in my Dakota booster and mastercylender
