Rebuild not priming correctly
Old Apr 19, 2011 | 07:12 PM
siggie30's Avatar
siggie30
Well the cap plug was indeed too shallow. When it was reassembled, I began priming and received an oil wash within 5 seconds from the oil sensor plug. After I put the sensor in the location I did it again, and the oil filter began gushing, so I will address that tomorrow by checking the oil filter galley plug. It could also be just a loose filter connector, but regardless, it is fixed.
Old Apr 19, 2011 | 09:10 PM
capricorn's Avatar
capricorn
New Member
The last illustration to this post is correct from what I've seen and read. never replaced that plug myself.
Old Apr 20, 2011 | 05:23 PM
capricorn's Avatar
capricorn
New Member
Default Galley plug
Yeah, that's the right position. It's a small cup plug that will only drive in so far from the bottom but it must be there.
I reread your post and see your also going to install a 5.9. Are you going to carb it or fuel inject? I just got a 5.9 and am ready to send it to the machine shop to check it out but trying to figure out what kind of ecm I need to upgrade to or if I need to at all?
Old Apr 20, 2011 | 06:15 PM
siggie30's Avatar
siggie30
https://dodgeforum.com/forum/1st-gen...read-carb.html
https://dodgeforum.com/forum/1st-gen...ert-build.html
