steering column removal?
Old Jun 22, 2021 | 10:48 AM
RWEJR's Avatar
RWEJR
Question steering column removal?
Hello: I replaced my rack IN pinion 2 years ago, needed steering column could not find one at the time, found one and can't get the column separated from the rack have all the bolts that I can see out column is ready to come out, just will not separate can some help thanks.
Robert
help separating
Old Jun 22, 2021 | 11:11 AM
I don't think it is supposed to separate there. Need to get it off down at the rack.
Old Jun 22, 2021 | 11:39 AM
RalphP's Avatar
RalphP
What HeyYou said.
That's so that they can have a tilt/non tilt column, and a 2WD R&P/4WD Recirc Ball gear box, and only have to mate the one to the other (instead of offering four different intermediate shafts).
Some heat may help it come back apart.
What you do for the rack end is, as you're aware, remove the roll pin.
(I say you're aware since you've already swapped the rack and pinion.)
RwP
Old Jun 22, 2021 | 01:57 PM
RWEJR's Avatar
RWEJR
It separated there when I removed and replaced the Rack IN pinion.
Old Jun 22, 2021 | 02:02 PM
RWEJR's Avatar
RWEJR
Originally Posted by RalphP
What HeyYou said.
RwP
Thanks I'll heat it up and see it that helps, can't get to the roll pin good enough to get a swing on it thought of that a while back this ones being a bugger. thanks for the reply.
