Exhaust Questions
Old Apr 12, 2007 | 05:34 PM
matt_s's Avatar
matt_s
Default Exhaust Questions
hey, so i was wanting to put dual exhasut on my truck, but im not sure were i should put the Y pipe. I was going to take off the cat, and then just run pipe. Were would u put it? How would it sound if i took the cat off, and then put the muffler were the cat was a then split the pipe after the muffler so it looks like i have dual exhaust?
thanks
Old Apr 13, 2007 | 09:43 AM
BAnders's Avatar
BAnders
Default RE: Exhaust Questions
cut the pipes off before the Y and run 2 pipes that way.or cut it off after the Y and run a single 3 inch pipe.i took my cat off, it sounds louder without it, but check local laws about it or get a high flow cat put on. i had an S-10 with duals with flows and no cat and it sounded good[/align]
Old Apr 13, 2007 | 04:17 PM
kahanabob's Avatar
kahanabob
What do you do with the seperate 1/2" air line off the pump that goes into the CAT?
Old Apr 13, 2007 | 07:34 PM
matt_s's Avatar
matt_s
thats a good question. what do you do whith that?
Old Apr 14, 2007 | 08:57 AM
BAnders's Avatar
BAnders
i dont remember my trucks having that air line, i'll look at it this weekend and post my findings.i guess either cap it or leave it open
Old Apr 15, 2007 | 12:02 AM
Kamokota's Avatar
Kamokota
a pretty simple way to make dual exhaust is to remove your muffler and replace it with a split tail performance muffler, this will only leave you the work of removing the muffler and tailpipe and fabing new tail pipes
Old Apr 16, 2007 | 06:26 PM
matt_s's Avatar
matt_s
ORIGINAL: BAnders
Did you happen to have a chance this weekend to look? b/c im going to be cutting my cat out this weekend and i was wondering what i might have 2 do if i have those puple lines.
I looked under my truck and this is what i c when im looking at the car, would i just cut the air line and then plug it?
thanks
Old Apr 17, 2007 | 02:02 AM
peckens's Avatar
peckens
I looked on mine and I dont have that at all. Try following it and see where it goes to, and if not sure take another picture.
Old Apr 17, 2007 | 11:05 AM
peckens's Avatar
peckens
Old Apr 17, 2007 | 02:38 PM
matt_s's Avatar
matt_s
yah thats the one, ive taken a coulpe pics of were it goes, im just on sure if i should plug it or leve it open, what do you think?
http://i110.photobucket.com/albums/n...f/SP_A0304.jpg
http://i110.photobucket.com/albums/n...f/SP_A0305.jpg
http://i110.photobucket.com/albums/n...f/SP_A0306.jpg
http://i110.photobucket.com/albums/n...f/SP_A0307.jpg
http://i110.photobucket.com/albums/n...f/SP_A0302.jpg
