dakota stalls on brake and clutch
Old Jun 23, 2007 | 12:06 AM
warchunks's Avatar
warchunks
Default dakota stalls on brake and clutch
ok so i have a 93 3.9 4x4 manual dakota and whenever i push in the clutch and then hit the brake the trucks stalls... what can i look at to try to fix this?
Old Jun 24, 2007 | 05:08 PM
gb6491's Avatar
gb6491
Default RE: dakota stalls on brake and clutch
Is it doing this when coming to a stop? https://dodgeforum.com/fb.asp?m=480163
Old Jun 26, 2007 | 01:53 AM
warchunks's Avatar
warchunks
no its like when you push in the clutch then brake then it will stall its also recently had a tune up and the whole distributor was changed
Old Jun 26, 2007 | 07:04 PM
belowrdr's Avatar
belowrdr
Sounds like the IAC could be getting sticky/slow, or the minimum idle air is setting is low - should be 400-500 rpm. That is what the engine will idle at when warmed up, in park, accessories off, and the IAC closed. Check this first - engine off, remove the air cleaner.Open the throttle all the way, anduse a spray can of carb cleaner to clean the build-up in the throttle bores & back side of the throttle plates. I like to use an old toothbrush to scrub the stubborn stuff with& then rinse with another shot of cleaner. The dirt build up & chokes off the air gap by the throttle plates. This may not fix it, but it's the 1st & easiest thing to check & needs to be done before this -Close the IAC cheater style, with engine warmed up, pull the brake booster vacuum line so the engine idles too fast. Wait 5seconds for computer to fully close IAC. Unplug IAC. Yes, this will set a code & turn the engine light on - don't worry about it, it will go away once plugged back in. Plug the brakebooster vac line back in - engine may try to stall, keep it running w/throttle, slowly closing to bringit down to idle - should be at min idle setting and running only off the throttle plate setting. If too low/won't run or too high (unlikely), drill out plug to access adjuster screw on throttle body & adjust.When done, plug IAC back in. Drive Happy.
Hope this helps - Good luck.
Old Jun 27, 2007 | 11:36 PM
78redrocket's Avatar
78redrocket
sounds like a vaccuum leak. Check all vac hoses carefully.
Old Jun 28, 2007 | 07:20 PM
jonnymagnum's Avatar
jonnymagnum
ya, sounds like a vacuum leak. mine used to do that all the time.
