Front end grinding noise help
Old Aug 17, 2007 | 10:43 AM
mauser95's Avatar
mauser95
Default Front end grinding noise help
Hi all. Started getting a loud metal on metal grinding noise from the left front on my 96 Dakotawhen braking to a complete stop. Replaced the caliper, both front rotors, and installed new pads. Noise is still happening. Seems like it only happens when coming to a complete stop from low speed. When stopping from highway speeds I don't get the noise (so far). Anyone got any suggestions? Was thinking it might be the hub, but there's no wheel movement when I jacked it up. Thanks forany answers.
Old Aug 17, 2007 | 01:39 PM
fishlessman's Avatar
fishlessman
Default RE: Front end grinding noise help
i changed the pads and calipers lately and had to take a grinder to the caliper to get the pad to slide properly, the aftermarket stuff didnt fit out of the box without a little modification. dont know how the 96 is, but the 89 shoes fit hard with long metal finger type tabs
Old Aug 17, 2007 | 09:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You can try greasing everything. the pads where it slides on the caliper bracket. where the pads are held in by the caliper. the slide pins (bolts) that holds the calipers on. The pads may also be istalled wrong or too lose.
Old Aug 18, 2007 | 04:04 AM
Nicegy525's Avatar
Nicegy525
you sure its coming from the front???? check the rear brakes
Old Aug 20, 2007 | 12:25 AM
mauser95's Avatar
mauser95
nicegy525 got it in one!! Everyone kept telling me the noise was from the front. Had my dad drive it around the driveway while I walked beside it. Could definately hear the grinding coming from the rear. Put new drums and pads on the rear and the noise is gone. Thanks again.
Old Aug 20, 2007 | 01:44 AM
Nicegy525's Avatar
Nicegy525
did you check the brake cylinders to make sure they werent leaking? Glad you got the noise fixed.
Old Aug 20, 2007 | 01:47 AM
Crazy4x4RT's Avatar
Crazy4x4RT
sorry if i gave you wrong advise. I asumed you checked where the noise was coming from. Im glad you got it.
Old Aug 24, 2007 | 11:12 AM
mauser95's Avatar
mauser95
Thanks for the replies guys it was all good advice. It was my bad listening to everyone tell me thenoise was coming from the front, should have checked the rear brakes sooner. Just glad I'm not getting scared looks from people everytime I come to a stop sign anymore.
