TBI to MPFI conversion??
Old Nov 14, 2007 | 08:21 PM
SRT4 Z24 GUY's Avatar
SRT4 Z24 GUY
Default TBI to MPFI conversion??
I have an 88 dakota 4X4 3.9L TBI. I would like to convert it to the newer style fuel injection with the injector per cylinder. First, can it be done? Second, what all would I need to convert it, I'm thinking intake, throttle body, computer and wiring harness. Am I gonna need the heads also or will the newer setup bolt to my heads?
Thanks in advance
Jason
Old Nov 19, 2007 | 10:23 AM
codydakota's Avatar
codydakota
Default RE: TBI to MPFI conversion??
On that model year, it won't be done easily, the MFI uses a different intake manifold, and PCM just for starters, and as yours is pre-mag, that would also hinder the conversion. You could swap in a magnum 3.9
Old Nov 19, 2007 | 08:59 PM
SRT4 Z24 GUY
I know this don't mean much but, it has the3.9L magnum emblems on the fenders. looks pretty original. I don't mind swapping intakes I'm just wandering if the MFI intake will just bolt to my heads, if not could I swap out the heads also?
Old Nov 20, 2007 | 08:29 AM
hemichuck's Avatar
hemichuck
The simplified answer would be No.The newer "magnum" heads had the intake bolts that went straight down instead of angled like the earlier motors and the Magnums also oil through the pushrods and not through the rocker arms so while it is possible to intermingle all of these parts,It's not a simple bolt on deal. Not to mention you would have to change the entire wiring harness,the fuel tank,pump and lines and a couple of other things to make it work.Nothings impossible but some things are not economicaly feasible.
Old Nov 20, 2007 | 10:12 AM
SRT4 Z24 GUY
Okay if I can't upgrade that way is there anything I can do to get some more power out of this thing? Also, I was told my truck probaly has a 904 tranny, if i'd swap in a 727 it would help free up some power. Any thoughts on that?
Old Nov 20, 2007 | 09:25 PM
wink2873's Avatar
wink2873
honestly there are no easy or cheap ways to get power out of a 3.9 pre-mag. I dont think your truck has a 904, i might be wrong but isnt a 904 actually a 727 with overdrive? you mentioned that it had magnum 3.9 emblems on the truck. For that year, someone wouldve had to put them on. I have an 88 and it just says"V-6 3.9 liter". Somone could've already swapped it to a magnum 3.9 i suppose. Just look at the engine and if you see fuel injectors and a fuel rail then it is a magnum.
Old Nov 20, 2007 | 11:23 PM
injmopar's Avatar
injmopar
Your truck will have a 904 trans if it is stock .If it had a 3.9 magnum swaped into it you would all ready have port injection .If you put a 727 into it, if anything you would loss a little HP.The 727 takes more power to turn .
Old Nov 21, 2007 | 09:58 AM
SRT4 Z24 GUY
Well thanks for the responses, I guess I'm stuck with this slow *** truck the way it is.
Old Nov 22, 2007 | 12:00 AM
injmopar's Avatar
injmopar
You could always get a V8
Old Sep 28, 2015 | 08:03 PM
Magnum cross89's Avatar
Magnum cross89
Has any body ever swapped modify motor and all in to an older dodge Wut is beaded to power up the computer I'm trying to help my brother he has an 89 dodge magnum and he put in a 318 magnum motor out of a 93 dodge that has the mpfi any help would be greatly thankful
