oil water
Old Nov 18, 2007 | 11:10 PM
jim deere's Avatar
jim deere
Default oil water
new to mopar and trying to figure something out.on the highway my 95 5.2 4x4 runs cold but the oil pressure runs real high almost off the the gage .i just put in a 180 thermostat ,and took out a 195 . i had to cut the hose it was glued so i will get in the am.i think i will pick up a cap also.any ideas i would appreciate it .thanks JIM
Old Nov 19, 2007 | 10:28 AM
jim deere's Avatar
jim deere
Default RE: oil water
well 180 thermostat and new cap.no change.maybe a set of after market gages.
Old Nov 19, 2007 | 07:38 PM
JetNoise's Avatar
JetNoise
Since you are having problems with your oil pressure, I would start with the oil and not with the coolant.
My first couple of estimates are to check you oil level and make sure it is within the proper range and not overfilled.
Another thing that will adjust your oil pressure is the weight of the oil you are using.
The best way to do both of these is to simply do an oil change. Pour in 5 quarts of 5w-30 oil and a new oil filter, then start it up and let it run for a minute. Then check your oil pressure guage.
Old Nov 19, 2007 | 07:54 PM
jim deere's Avatar
jim deere
thank you .i went to autozone when i got the truck.he told me to use 4 qt's 10-40 with a qt of lucas.i told him it had 217k when changing the oil i noticed some paint marker on the oil pan.so i would assume it is not original.i guess i will change the oil.the temp of the water is lower with the 180.i think a set of gages soon.thanks again.
Old Nov 19, 2007 | 08:31 PM
JetNoise's Avatar
JetNoise
I usually use 5w30 because I don't like where my oil pressure guage goes to when I use a heavier weight. And I always use a lighter weight oil in the fall and winter because it is easier on my motor. Also, Lucas Oil Treatment is heavy stuff in and of itself.
The coolant (water) is going to be cooler with the 180 thermostat because it opens sooner than OE, so it starts cooling the engine sooner. I , myself, stuck with the OE temp when I replaced mine.
Have fun with the guages. I like mine too much to give them up....
Old Nov 19, 2007 | 09:05 PM
jim deere's Avatar
jim deere
i think i will drop the oil in a day or so.ill try the 5-30 we will see if that helps im shure it will.thanks
