5.9L R/T Heads on 5.2L
Old Dec 6, 2007 | 08:17 PM
V8DAKOTAV8's Avatar
V8DAKOTAV8
Default 5.9L R/T Heads on 5.2L
Anyone know if 5.9L Dakota R/T heads will bolt on to my 96 5.2L?
Old Dec 6, 2007 | 08:49 PM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: 5.9L R/T Heads on 5.2L
yes they will, i have a mopar magnum performance book and it says you can do it!!! i wish i had some r/t heads[&o].
Old Dec 6, 2007 | 09:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Haha Bad96_3.9 I do. Well not realy I just got the enigne from a dakota rt not the truemopar rt heads. I wish I did too.
Old Dec 7, 2007 | 12:37 AM
V8DAKOTAV8's Avatar
V8DAKOTAV8
Well I have a guy here that wrecked his 00 R/T. It has 68,000mi on it. He sold alot of the parts already but kept the engine to rebuild and put into a 78 Grand Wagoneer but his dad told him he needs to get rid of the "projects" sitting in his yard. lol. He told me he would sell me the heads, Intake, and throttle body setup for 250.00 or the whole motor for 600.00. Should I just buy the whole thing? If not, will I need the computer if I use his throttle body too?
Old Dec 7, 2007 | 02:52 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Get the entire engine. You will be glad you did. Thats what I did. You can use your stock computer. The only thing you will need is the harmonic ballancer and flexplate and injectors+ connectors from the 5.9. everything else stock will work. just use your 5.2 sensors.
And just so you know even tho it is coming from a rt truck it does not have rt heads. No stock truck came with the RT heads.
Old Dec 7, 2007 | 03:41 PM
fox's Avatar
fox
lucky....
Old Dec 7, 2007 | 04:02 PM
Bad96_3.9's Avatar
Bad96_3.9
ORIGINAL: fox
lucky....
x2
Old Dec 7, 2007 | 11:28 PM
V8DAKOTAV8's Avatar
V8DAKOTAV8
Yea Crazy I realize that. However, I am under the impression that the 5.9 Heads flow a little better than the 5.2. Right?
Old Dec 8, 2007 | 01:42 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Right they do. But getting the entire engine is going to be better than the heads. Im only guessing but the head swap may be good for 10 hp or so. the engine 30-40hp.
Old Dec 8, 2007 | 01:28 PM
V8DAKOTAV8's Avatar
V8DAKOTAV8
Good deal. I'll get the whole thing. Thanks for the info.
