Really High Oil Pressure
Old Dec 10, 2007 | 06:49 PM
alterboy's Avatar
alterboy
Default Really High Oil Pressure
Just wanted to know if you had any Ideas why i have high oil pressureand anyreprocutions for not fixing it! Thank you
[IMG]local://upfiles/77401/F28B4DB9C10248AD896B98D01BBC4EDB.jpg[/IMG]
Old Dec 10, 2007 | 07:26 PM
daksport91's Avatar
daksport91
Default RE: Really High Oil Pressure
yikes... im curious as to what is causing that... u check the oil level to see if its good?
Old Dec 10, 2007 | 07:30 PM
fox's Avatar
fox
could be ur relief valve is stuck closed on the oil pump
Old Dec 10, 2007 | 07:45 PM
Bad96_3.9's Avatar
Bad96_3.9
i thought i had high oil pressure all of the time till it blew the top off of the oil pressuer sending unit going down the road, the new one does not stay up there all of the time, it stays about in the middle or a little lower, so you may want to keep an eye on it.
Old Dec 10, 2007 | 08:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I know the oil sending unit does regularly act up. I had 2 leak on me. Just check your oil level and make sure your using the corect oil. too thick of oil can cause this I think.
Old Dec 10, 2007 | 08:11 PM
Bad96_3.9's Avatar
Bad96_3.9
yea, i run valvoline10w40 in mine, a little thicker than usual, but i never hear lifters or anything else ticking! the sender actully popped the day after i changed the oil!
iraqvet's Avatar
iraqvet
I've also seen theproblem with mismatched components...i.e. a30 PSI sending unit transmitting to a guage designed for 20 lbs max.
Old Dec 10, 2007 | 09:31 PM
92BLACKLS's Avatar
92BLACKLS
You could also check the PCV, might just might be some what of the problem, thick oil will do it to but I used lucas oil once before and I didn't notice a pressure change and that stuff is like thick syrup.
Old Dec 10, 2007 | 09:35 PM
Bad96_3.9's Avatar
Bad96_3.9
yea, i run lucas every other oil change, that is some good stuff, i put half a bottle in my rearend when it was roaring, has quieted down ever since and that was about 50,000 miles ago!!!
Old Dec 10, 2007 | 09:41 PM
92BLACKLS's Avatar
92BLACKLS
Damn yea I'm thinking im gonna put some lucas back in there after she burns some more oil down, when I replaced my rear seal behind the drum I just used some synthetic oil and i didn't notice a difference. BTW alterboy not to change subject but your dashboard is really nice and bright, did you change the bulbs behind there because mine is to dull
