BURRNING LOTS OF OIL
Old Dec 15, 2007 | 01:43 PM
Dodge man Dan's Avatar
Dodge man Dan
Default BURRNING LOTS OF OIL
Can anyone help me out. My truck burns oil put 2qts in last week and is at bottom of safe operation mark on dip stick!
Old Dec 15, 2007 | 03:14 PM
dodgerules86's Avatar
dodgerules86
Default RE: BURRNING LOTS OF OIL
When does it burn the oil. Does it mainly burn it when first starting up, and at acceleration, or all the time?
How bad would you say the cloud of blue smoke is? For instance, on my grandpas van, when he would take off, it would leave a pretty good size cloud behind it (enough so that the cars would stay about two or three car lenths back). In his particalur case, it was the valve stem seals.
Any oil leaks?
Old Dec 15, 2007 | 03:52 PM
wink2873's Avatar
wink2873
engine/year would help also
Old Dec 15, 2007 | 11:48 PM
fox's Avatar
fox
I second that on the valves my seals were leaking on mineand couple rings shot on the other cylinders lol and my presseure sender sensor was barly hanging on there and yet it would read correct oil pressure on the dash. [:-]
Old Dec 16, 2007 | 09:39 PM
steve05ram360's Avatar
steve05ram360
check the plenum gasket...
Old Dec 17, 2007 | 01:01 PM
arcsum68's Avatar
arcsum68
Yup, that much oils gotta be the plenum gasket.
Search for my posts for a picture of what your gasket probably looks like.
https://dodgeforum.com/m_1089128/mpage_1/key_/tm.htm
There, first pic is of the gasket, apparently they over torque them at the factory and the metal between the intake and plenum expands at different rates causing even more problems.
Just realized this wasnt the Ram section, may still apply, not sure though.
Old Dec 18, 2007 | 05:07 PM
Dodge man Dan
how much does it cost to do the gasket, is it hard?
Old Dec 20, 2007 | 07:34 PM
wink2873's Avatar
wink2873
if your truck is a v6 or v8 magnum go to www.hughesengines.com they have plenum gasket repair/reinforcement kits. I just installed one on my 2001 3.9 when i swapped to a stage 1 manifold. basically you just have to take off all the belts and hoses, fuel rail and intake manifold. it took me like 3 days but i could only work on it for like 2 hours at a time... so it could be done in a day.
