spark plugs
Old Jan 2, 2008 | 03:07 PM
milky9788's Avatar
milky9788
Default spark plugs
Whats the best plugs and wires for a 318?...i have ngk plugsandaccel 8mm wires and they aren't doing anything for me
Old Jan 2, 2008 | 03:15 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: spark plugs
autolite copper core 3923's.
Old Jan 2, 2008 | 04:24 PM
Cutlass84's Avatar
Cutlass84
I am using champion truck plugs. Didn't notice much of a difference, but read rave reviews about them in 318/360s so I went with them.
Old Jan 2, 2008 | 07:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT
ORIGINAL: Jr. Mechanic
Ya I would have to agree. I have had the bosh platinum+4. These fell better. They are just one step colder than stock. Which is 3924. If you want to go 2 steps colder. go with 3922. These are good for higher performance like niturs or supercharger, but not good for stock or little mods.
Old Jan 2, 2008 | 07:22 PM
95V8Dakota4x4's Avatar
95V8Dakota4x4
You're never going to get a worthwhile difference out of plugs and wires unless the stuff you're replacing is total garbage. But at that point any tune up will do. Ignition systems are victim to some of the worst voodoo racing ignorance there is, until you're turning 6000rpm and/or running race gas your stock ignition system will likely be up to the challenge. Some vehicles can benefit from an upgrade if they're meant to run low octane but are consistantly given high octane, but even then you have to startfurther up the line fromthe plugs and wires. There are no magic plugs and wires that will give you extra power.
Old Jan 2, 2008 | 07:42 PM
milky9788's Avatar
milky9788
I want something besides ngks (i heard ngks are for like imports and some V6s) and it doesn't sound like i'm getting a spark with them...what octane does everyone run? i run 89 when i can
Old Jan 3, 2008 | 09:25 AM
JetNoise's Avatar
JetNoise
I am running Champion plugs on 87 octane and my truck does exactly what I want it to, when I tell it to. I stomp on the gas, she hauls...
Old Jan 3, 2008 | 01:42 PM
whiteonrice's Avatar
whiteonrice
ORIGINAL: milky9788
NGKs are preferred by a lot of High Performance people. I run them in my Procharged 550 horsepower Corvette.
Old Jan 3, 2008 | 09:23 PM
95V8Dakota4x4
ORIGINAL: milky9788
Whoever told you that was talking out their ***, plugs are specific to their intended application. NGK's are great plugs regardless of the application. If you're not getting spark you're barking up the wrong tree, you won't fix that problem with different plugs. Also, 87 octane is just fine for your truck. 89 is too, but it's more expensive, so ultimately it's a waste of money. Our motors do not have very high compression.
