May have wrong tranny fluid? Weird problem
Old Jan 3, 2008 | 10:45 PM
noodle's Avatar
noodle
Default May have wrong tranny fluid? Weird problem
About two months ago, I broke a tranny cooler line and leaked out a **** ton of tranny fluid. At the time, i didnt know that i shouldnt use dexron or mercon tranny fluid. I added a gallon of cheap fluid from my Advance Auto Parts. My problem is that i dont know if it was dexron, mercon, or the correct atf 3 or atf 4. I dont remember the brand, the color of the bottle, or anything. Is there anyway of telling what is in there? I would go get a flush but i have heard way to many bad things about them. I would drop the pan but i wont be able to get all the fluid out. For all that I know it is the correct fluid, but having the reputation that Dodge can have, I dont want to risk it. What should i do?
Old Jan 4, 2008 | 01:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: May have wrong tranny fluid? Weird problem
go to a relible shop that will do a flush. if done correctly there should be no side affecs
Old Jan 4, 2008 | 03:17 AM
fox's Avatar
fox
HA I did the same thing with my power steering I didn't know that our PS system don't use ATF fluid but actual PS fluid
Old Jan 4, 2008 | 10:28 AM
Crazy4x4RT's Avatar
Crazy4x4RT
How well did the ATF work in the power steering! Did it feel the same. They both are hydrolic fuild.
Old Jan 4, 2008 | 11:59 PM
fox's Avatar
fox
Nah it was real looooooooose I could literly shake the steering wheel back and forth without the truck barely moving, bleed the system and put the right fluid in there and it worked fine
Old Jan 5, 2008 | 01:42 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: noodle
I added a gallon of cheap fluid from my Advance Auto Parts. My problem is that i dont know if it was dexron, mercon, or the correct atf 3 or atf 4. What should i do?
atf+4 is about $5/qt, so a gallon would have been about $20. i'll bet you remember that it wasn't that expensive. you almost certainly have the wrong fluid, and should change it a couple of times or flush it. what i would do is drop the pan, change the filter and fluid (atf+4), and add a generic bolt in drain plug to the transmission. then after a few days, use the drain plug and drain/refill again. its not perfect, but its close and it will cost you a lot less than a flush. you'll need about 6-7 qts for each drain/fill, a filter/gasket kit, and a $5 plug.
http://www.pavementsucks.com/tech/trans.php
Old Jan 5, 2008 | 08:53 PM
noodle's Avatar
noodle
Yah. ****.
