headlights
I have a 96 dakota 3.9L, this morning when I was heading to work, the headlights came on. I drove roughly a mile to the gas station and when I left i got about a quarter mile down the road. Both headlights popped off and died. I trieded pulling the switch a few times and nothing....everything else on the truck works good. If you hold the highbeams they also work.
So...I checked the fuse box, In the manual it said the headlights were connected to a circuit breaker type fuseunder the hood in the front...checked that got a new one and still nothing....where do I go from here?
mine were i had the same problem, accept when i turned mine on they popped...this thread will help, buy new bulbs first though...
https://dodgeforum.com/m_629010/tm.htm
Did you change your bulbs with aftermarket ones? I burned out 3 switches in 2 months with my Xenon bulbs, It must have been drawing too much power and just started melting itself... I just went to the junk yard and got a diffrent switch. Hope that helps.
its the switch that happened to me to if i played with the switch for a wile it would come on. when they burn out only the parking ;ights will come on it burns the head light part out. the switch is only like 15 dollars at least where i got it.
yea, a weird thing happened i tried them at my lunch again....the lights worked and have been working since? They are not aftermarket bulbs, just regular replacements.
Do you think I have a loose connection, or a switch going bad? I don't want it to happen again.
