Cluster Lights
Old Mar 19, 2008 | 10:10 PM
Bad96_3.9's Avatar
Bad96_3.9
Default Cluster Lights
has anyone changed the color of the gauge cluster lights? I have been wondering if it could be done on these, i really dont like the green ones, i want to swich them to red like everything else in my truck. i dont know if it is a film or just a cover that makes them green? My moms jeep had white lights in it so i put some blue L.E.D.s in there and it looked awesome. just dont know how to get rid of the green on these.....
Old Mar 19, 2008 | 10:59 PM
dodgerules86's Avatar
dodgerules86
Default RE: Cluster Lights
The green is "implanted" in the black plastic covering. If you take out the cluster, it uses plain white bulbs.
I agree, it would be nice to change the color. Unfortunatly, doesn't appear to be much, or anything, aftermarket for our gauges.
Old Mar 20, 2008 | 12:39 AM
OneBadKota's Avatar
OneBadKota
If I remember correctly, the green pieces on the back of the cluster(each gauge) can come off and the bulbs can be replaced to whatever. However, those bulbs are one of the hardest little buggers to remove. Have to be careful, they will break easy.
Old Mar 20, 2008 | 12:51 AM
dodgerules86
... maybe I should have dug a little deeper when I was fixing the electrical connector. Oh well....
Old Mar 20, 2008 | 09:12 AM
jlbritt1's Avatar
jlbritt1
Or instead of changing the bulb color, you can get gels from a stage lighting supplier and use them in place of the green. Gives you just about any color you want for your gauges, even a multicolor combo setup. Haven't done it to the Dak (yet), but did have them on my '81 280ZX.
Old Mar 20, 2008 | 11:04 PM
Bad96_3.9's Avatar
Bad96_3.9
i guess one day i will get around to pulling it apart to see, i might just get one out of the junkyard and mess with it, i have been wanting to get one with a 125 mph spedo anyways!!!
Old Mar 21, 2008 | 10:08 AM
OneBadKota's Avatar
OneBadKota
I believe the 125 speedo's are only a mechanical and not an electrical one. At least the one I bought it, and that's the reason I bought it.
Old Mar 21, 2008 | 10:08 PM
Bad96_3.9's Avatar
Bad96_3.9
damn, way to crush my dreams..., lol. i am glad you said something before i got it though!
