Water pump replacement
Old Jul 16, 2010 | 03:11 AM
  #21
jimbo74's Avatar
jimbo74
ok just went outside, that boss i am talkign about is liek an inch protruding and like an inch in diamter or there abouts....
it isnt the pipe pictures above, that pipe is liek 1/2" and way longer, and is to the right when facing the engine of the big boss
Old Jul 16, 2010 | 03:13 AM
  #22
jimbo74's Avatar
jimbo74
oh, haha, i thought this was my new thread i started
here is the link to it
https://dodgeforum.com/forum/2nd-gen...mp-issues.html
and the truck i am working on is a second gen
however, i think the dodge 3.9l engine has been the same forever
Old Jul 16, 2010 | 08:30 AM
  #23
jimbo74's Avatar
jimbo74
any more thoughts?
Old Jul 16, 2010 | 12:49 PM
  #24
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by jimbo74
i don't think that is it....
that boss attaches to a hose and it is above the pump, liek right in the middle, not bellow it where that longer metal tube is
also, it says to use an o-ring for that pipe, and i plan to get the pipe, but i don't know anything about the o-ring for it....
Oh okay you are right. It is the bypass hose that goes into the intake manifold. Replace that hose, it is a PIA to replace if it busts in the middle of no where.
If I still remember right that insert is threaded. It may be better to buy a new insert as well as the heater output tube that I posted a picture of, it is a common leakage problem.
If I remember right you asked how to drain the system. The lower left side of the radiator has a drain valve. Unscrew then it drains.
