leaks and floor board full of water
Old Jan 4, 2005 | 12:15 AM
92dak's Avatar
92dak
Default leaks and floor board full of water
I have a 92 dakota which when heavy rains come my floor boards fill with water. I have yet to find the leak. I would like some possibilities as to where to start. Thought possible weather stripping but still leaks.
Old Jan 4, 2005 | 02:58 PM
GMsucks's Avatar
GMsucks
Default RE: leaks and floor board full of water
Water leaks aren't any fun to find. You actually have to get out the garden hose, make it rain, and look for the source of the water leak.
Old Jan 10, 2005 | 01:51 AM
prowlertech01's Avatar
prowlertech01
if you think you have a weatherstrip or seal leak, try this,,, start the truch ,close all doors and windows,turn the blower fan on high and get a bucket of soapy, soapy water and wash the truck. watch for any bubbles around the door seals and windows. my extended cab 94 dakota had a roof mounted red fire light which when removed left dents in the weatherstrips which i had to replace..if it has air conditioning check the evaperator drain to see it it is plugged.
Old Jan 13, 2005 | 01:02 AM
92 dakota 193k's Avatar
92 dakota 193k
Mine does the same thing, already replaced the weather strip (passenge side), but went the cheap way with the universal model instead of the outrageously priced dealer "built to fit" model. Wonder if that might make the difference. For that price I guess I'll never know. Shop vac works well.
Old Jan 25, 2005 | 10:59 PM
lilreddakota's Avatar
lilreddakota
check heater blower resistor on firewall-water runs down behind hood on firewall and into heater if this is loose. happened to me[:@]dummy left the screws loose i guess
Old May 21, 2005 | 09:44 PM
pembroke dude's Avatar
pembroke dude
is the water on the passenger side ??
if so there may be some sealer missing on a body seam under the wiper cowling i had a wind noise and thats what i found on my truck
i found a T.S.B on mitchel
Old Jul 14, 2005 | 02:32 PM
trukn2004's Avatar
trukn2004
I have the same problem in my truck. i gutted the whole interior and found it leaking from the back window. mine was puddling in the back and then running to the front. the water is entering in between the window and the gasket.so far i replaced the back window and weather stripping,and ran a bead of silicone in between the window and the gasket and then the gasket and the body, but it hasent stopped. im in the process of looking, since i have built a full custom interior(save seats). i talked to a guy who told me to take a hose and run it on the window in small parts until i see the leak again. then he said to move to body seals. good luck i will let you know if i find mine.
Old Jul 29, 2005 | 02:16 PM
trukn2004's Avatar
trukn2004
Found my Leak, it was the back window, just wasent sealed right. now it is waterproof and i finally got the interior in.
