3.9 to 318 swap info!!!
Old Feb 9, 2018 | 10:32 PM
  #21
RalphP's Avatar
RalphP
Originally Posted by Jocam75
I have a 96 Dakota 2 wd and want to put a v8 in it . if I get the wiring harness from a 95 dakota and the engine from the same truck . can I use the wiring harness in my 96
Some yes, some no.
Remember, the 1995 and earlier used SBECs or SMECs; the 1996 is a JTEC, completely different CPU and with OBDII coming in for 1996, some changes in the cab harness and the bulkhead harness also.
OTOH, all you need to add is the two extra injector wires, and swap to a V8 ECU, for the wiring.
RwP
Old Feb 9, 2018 | 11:35 PM
  #22
Toby Warford's Avatar
Toby Warford
I have a 96 5.2 auto computer is sell dirt cheap if you're interested. I put a 5.9 in my truck.
Old Mar 22, 2018 | 02:21 PM
  #23
Jocam75's Avatar
Jocam75
Default Need info.
What transmission did you use?
Old Mar 22, 2018 | 02:23 PM
  #24
Toby Warford
stock trans. Same as the 3/4 tons gassers got anyway. That computer I had is long gone though.
Old Mar 22, 2018 | 04:26 PM
  #25
Jocam75's Avatar
Jocam75
Default Trany
Will the trany out of a 96 1500 with the 318 plug into my truck or will I have to stick with the v6 trany
Old Mar 22, 2018 | 04:58 PM
  #26
Toby Warford
of course. Why wouldn't it?
Old Mar 22, 2018 | 08:35 PM
  #27
Jocam75's Avatar
Jocam75
Default Trany
well I've got the 3.9 transmission and I didn't know if I'd have to change the wires on the trany to fit the v8 trany. Just trying to get all my ducks in a row before I commit cause my daily driver...
