ABS and Brake light on
Old Jan 22, 2012 | 10:41 AM
RockGuardedDak's Avatar
RockGuardedDak
Originally Posted by Cutlass84
well it turns out both the lights were on because the stop light fuse was on.
So, if you have these lights on your dash lit up, very good chance you have no brake lights.
I feel stupid for not checking sooner!
This is not necessarily true, as both my ABS and brake light are on, but my brake lights work. Those lights will come on in unison to inform the driver of one of many different problems...
FOR EVERYONE BELOW THIS POST
AZ 96Dak
Yes, those lights will come on if there is a leak. Mine is leaking in the exact same spot as yours (On the T) and both of my lights are on..
dodger8691
Check for a leak. You mighta blown a brake hose, you never know. Any difference in the brake pedal when you go to stop?
Old Jan 22, 2012 | 06:07 PM
dodger8691's Avatar
dodger8691
Originally Posted by ColinSLC56
I have this same problem every now and then. After it sitting for a few days, or after a good run at the mud, the ABS and Parking brake/emergency brake lights are both on. I just ignore it and they usually turn off. Once, I disconnected the battery for a little bit (I did an hour, half hour should be fine). While you've disconnected the battery, check the black case on the driver's side of the engine compartment which the lid pops off. Check the sticker on the top of the lid to see where the ABS and Brakes are, pull out the switch and put it back in. This should help, if you haven't fixed this already.
Has it stayed on or has it gone away? Like I said, mine usually goes on randomly or when the brakes get wet. (1993 Dakota 5.2l v8 4spd auto, 4x4)
mine haent gone away yet i will take it to work and just used the code scanner to delete it
