hockey puck suspension
Old Jul 27, 2008 | 05:08 AM
dodgerules86's Avatar
dodgerules86
Default RE: hockey puck suspension
ORIGINAL: Bad96_3.9
thats kind of cool, those things are pretty hard. i already hve polygraphite bushings in mine, they work pretty good too!
You 2WD guys get all the good stuff. I remember looking for good bushings for my truck and wasn't able to find anything. Of course, I don't always know they best placed to look, but the main placed cater to 2WD.
Hockey pucks, I'll have to remember that for when I replace my bushings!
Old Jul 30, 2008 | 05:33 PM
fwtc's Avatar
fwtc
no problem folks, anything to save a few $ works in my world.
Old Aug 4, 2012 | 10:26 PM
RobertMc's Avatar
RobertMc
What difference is there between the 1st gen 2wd and the 4wd bushings ?
Is it simply thickness ?
If so.. any advantage to using the prothane 2wd kit along with pucks on top of them ?
Wouldn't using alone pucks make the cab ride hard ?
Old Aug 4, 2012 | 10:30 PM
pinkfloydeffect's Avatar
pinkfloydeffect
I thought about temporarily using pucks for my rear cab bushings, they squeak! Also as a cheap way to wedge the coil springs back to stock height in the front for a few months.
Old Aug 5, 2012 | 12:27 PM
dodger8691's Avatar
dodger8691
i have herd of them for blocks for the rear never thought about body mounts though
Old Aug 6, 2012 | 12:21 PM
buick's Avatar
buick
I did a 2" puck body lift all the way around on my truck. I would say they are just fine for looks/on-road use. After one heavy offroad wheeling trip, the cab mount pucks are starting to compress, leaving a noticable difference in cab/box heights, also giving reduced clearance up front. I'm going to be replacing mine with custom pipe/washer bushings to ensure clearance and reduce sag at the cost of ride quality.
Old Aug 14, 2012 | 03:56 PM
RobertMc's Avatar
RobertMc
In my case I'm looking for the 4x4 stock height.
I figure I'll give using the energy suspension 2wd cab mount bushings a try for the 4wd.
I can't see why they would be different. (except maybe thickness, which pucks should solve)
