Gutting the Catalytic Converter
You wont be able to pass emissions with a gutted cat. And im nort 100% sure but I dont think you can pass with the high flow. I have even heard from one guy that said he replaced his with oem and failed emissions because he had it tested right after it was installed. He said he had to run the truck for a little while then take it back.
Licensed Plumber here, you are dead wrong - pipe size has nothing to do with pressure. You will have the same pressure in a 3/8" pipe as you would in a 1 1/2" pipe. The increase comes in volume, you simply restrict the opening, restricting the the volume and creating a spray effect...
Pressure is created from either a pump or gravity, it can not be increased by reducing tubing size.
Also it passes the visual inspection of a cat installed, but if the tech wants to be an A$$ about it sounding hollow they may fail it.
But just like every vehicle is different it may not work for everyone.
Yes I pass my city emission tests. I had hollowed out my cat about 8 years ago or so. Every 2 years I need to retest, every time it passes. I have a strong clean burning engine.
WOW I never would have thought that a gutted cat would pass inspection.
I needed a new manifold/cat for my Civic and after a lot of research it came down to not screwing with the factory. If I put anything on it other than factory spec it would lose power and fuel mileage.
A V8 is no different. These Dakotas can be made to be better but unless you are going with more power putting a big high flow exhaust on them will be a detriment. They need backpressure to run correctly. Otherwise you will find the computer is having a hard time adjusting and can give bad reading from the 02, AIC, and other sensors.
Where backpressure is located is also important. But for factory vehicles, don't screw with the A/F ratio to much.
drag racing and real world vehicles are different animals. To big exhaust and you lose backpressure which drops power, to little exhaust and you choke it off. Find the sweet spot and roll with it.
http://www.importtuner.com/features/...l/viewall.html
