1996 Dodge Dakota 5.2l A/T 2wd
Ok i just bought the Dodge listed above and was told by the owner that the a/t need a trans pump for it because he says that when you drive about 10 miles and the a/t warms up it then has no pull and go into 2nd? Now my initial thought were to change the filter check fluid inspect the trans lines and clean them out and replace the radiator(sp)... Any other thoughts on this???
jeff
jeff
RE: 1996 Dodge Dakota 5.2l A/T 2wd
it would not hurt, you could take it to a shop and get them to do a pressure test on it too. they make a can of flush that you disconnect the lines and hook it to one end and it flushes it all out including the radiator. that and a tranny filter is alot cheaper than getting a front pump put in!!!
Hello all,
Well i have flushed what was probably only 3 to 4 qts out of the tranny by disconnecting the output oil line from the tranny pump and ran the truck to pump out all the oil and noticed that the oil was a milky color and also looking and the debri in the pan there was microscopic particles as well as a couple pebble sized pieces. Well after changing the fluid/filter adjusting the bands cleaned out all the lines the truck now drived pretty well. BUT however i noticed that there is a leak. There is fluid comming out of the throttle lever/gear shift lever area on the left side right by the reverse sensor.
Any idea if that is a rubber O-ring or bushing i can replace myself? If so what are the correct names and part #'s for the pieces i need and can i replace them with the tranny in the truck?
vizi
vizi
