Does replacing ECU require VIN burned into new one
Old Sep 3, 2008 | 04:57 PM
HP480's Avatar
HP480
New Member
Default Does replacing ECU require VIN burned into new one
Reading up on rebuilt ECU's, I understand that you have to bring the truck to a dealer and have the VIN burned into the replacement ECU, before it will even run.
Any trueth to that? Local Dodge dealer says so and wants $90 to do it.
If that's true, how do you do it to a used one from a different truck?
Old Sep 3, 2008 | 11:18 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No you dont have to. Just make sure you get the same year and eninge and transsmission as your stock one.
Old Sep 4, 2008 | 03:24 PM
codydakota's Avatar
codydakota
Like crazy said, on these you don't need to, but on the newer vehicles you do for emissions testing purposes, if they see a different vin come up on the computer than what's on the truck, they'll fail you for "tampering with emissions control systems"
Old Sep 4, 2008 | 09:37 PM
Bad96_3.9's Avatar
Bad96_3.9
they did not start flashing the comps with the VIN until 98. so we are lucky!!!
