Cheep lift!
Old Mar 2, 2009 | 04:46 AM
  #21
Blue 12's Avatar
Blue 12
just finished doing this. i added 3/4 of an inch and it gave me 2 in of lift. when i rock the truck back and forth hard, it seems to bottom out the shocks a bit. they are old so i may just replace them with a set of 2 in longer skyjackers in a few weeks when i get some extra cash
Old Mar 2, 2009 | 08:17 PM
  #22
Crazy4x4RT's Avatar
Crazy4x4RT
Cool! Do you have any pics of the keys? Any problems?
Old Mar 2, 2009 | 11:02 PM
  #23
Blue 12's Avatar
Blue 12
no problems other than i had to heat one key to get it off the torsion bar(rusty) and i gave myself a good burn being careless lol. it was easy to get them back on. just used a pry bar on the torsion bar to get clearance to slide the keys back on. could have added more to the keys for more lift with no trouble getting them back on. i used some 1/2 inch round stock and 1 piece of 1/4 flat. welded on with a stick welder. i had 8 in of clearance before
Old Mar 3, 2009 | 11:23 PM
  #24
Blue 12's Avatar
Blue 12
ok it wasnt the shocks bottoming out, it was the stoppers hitting like they are supposed to. which leads me to believe that if i take the stoppers off to get more travel it would bottom out the shocks unless i put in longer ones, so when i get diff shocks ill take out the stoppers
Old Mar 3, 2009 | 11:42 PM
  #25
Crazy4x4RT's Avatar
Crazy4x4RT
Cool! That key looks cool!
My bumper stops, the ones your talking about are gone, due to damage. I do not bottom out the shocks. I added a spacer to the top to give me a little more flex from it. But stock style shocks.
Old Feb 24, 2010 | 11:27 PM
  #26
LO 619's Avatar
LO 619
I can do this pretty easily in class. I assume i need to jack the truck and put it on stands? if so I'll need to borrow someones axle stands and jack to do this.
Old Dec 31, 2010 | 12:09 PM
  #27
kevinbarnhart1992's Avatar
kevinbarnhart1992
After seeing this post I took my keys off and did the same thing. Took me about 30 min from start to finish and gave me enough lift to put 2 inch block in the back and it will still set level. Works just as good as new key would. Now I have 4 inches of lift(2in body and 2in keys & blocks) for less then 130 dollars.
Old Jan 6, 2011 | 03:21 AM
  #28
89newbie's Avatar
89newbie
Unhappy
Originally Posted by Blue 12
thanks! ill go 3 in the front this way, 3 in the back with blocks, and try for 3-4 with a body lift. that should give me room for ok sized tires
I understand the torsion bar thing but I dont know what the referance to blocks for the rear is.
I spent some time today on the 94, seems the right torsion bar was cranked higher than the left (driver side). Added a pair of helpers to the rear previously for weight I carry truck is now level, except for, lol drivers front is 1/4 inch lower than the pass. Rear passenger is 3/8 higher than driver. Fiddled with it quite a bit figure its from a previous owner getting hit in the pass rear.
K Found blocks at zone. Got two inch. I was lucky a Gen 2 was parked in the lot so I was able to compare. With the helper springs and 2 inch blocks I will sit aout 1 inch higher than the Gen 2 was and when pulling the trailer I should be good.
OH Chit Just realized, If I got 3 inch blocks the truck would be running down hill all the time, Id never have to buy gas again !
