home made posi trac?
Old Oct 30, 2008 | 12:29 PM
95_318SLT's Avatar
95_318SLT
And to add to what crazy said, the factory gears in our trucks are 3.90 and 3.55. If your's is a 4x4 than you absolutly have to keep with the same ratio unless you change both the front and back, if its 2 wheel drive it's up to you on the ratio. You'll get better acceleration with the 3.90 but you'll get a lot better gas milage on the highway with the 3.55
Old Nov 1, 2008 | 02:36 AM
Crazy4x4RT's Avatar
Crazy4x4RT
LOL I guess its perfect timing. The newest edition of Petersen's 4Wheel & Off-Road They wrote up an artical about welding spiders.
Old Nov 1, 2008 | 11:11 AM
Blue 12's Avatar
Blue 12
awesome! thx for posting
Old Nov 3, 2008 | 12:08 PM
skife's Avatar
skife
seriously though, go with a mini-spool, they usually run about $100ish and you can pull them out incase you want to go back.
Old May 27, 2009 | 03:37 PM
RockGuardedDak's Avatar
RockGuardedDak
i know this is an old tread, but i was looking into the options of my rear end, and i wanted to clear this up with you... my dak came from the factory with a 3.50 ratio in the rear end. i dno if it was a special option, but i just wanted to let you know, the 3.50 ratio was there. i have the factory 8.25 diff too
Old May 27, 2009 | 04:53 PM
95_318SLT's Avatar
95_318SLT
Yeah, my neighbor who has a '95 Dakota 4x4 with the factory towing package has 3.50 listed as the ratio on the info sticker under his hood. That confused the heck out of me when I saw it cause if you look at any differential supply website, nobody sells a 3.50 ratio ring and pinion. I don't know if it's a typo on Dodge's part or not, but I'm still having a hard time believing it based on the fact that the parts don't exist.
Old Sep 19, 2010 | 12:07 AM
9652dakota's Avatar
9652dakota
3.21 acording to the options list i pulled for my vin on dcx. posi 4x4 5.2 .
