Roll call! Post up Pics!!!
Old Dec 11, 2011 | 09:47 PM
  #281
shadowthedakota's Avatar
shadowthedakota
Originally Posted by frustratedowner
I bought this truck 2 days ago. It's a 92 Dakota, V8 Magnum. It has a shift kit that I really hate and will be posting about in another thread.
It has extremely low mileage on it, I don't know why, but I'm not complaining about that at all.
nice it looks exactly like mine minus the rust and the cap
Old Dec 11, 2011 | 09:56 PM
  #282
frustratedowner's Avatar
frustratedowner
Quite similar, but a year apart.
Old Dec 12, 2011 | 02:40 PM
  #283
caraudiocrazy5150's Avatar
caraudiocrazy5150
Default First Gen dakota double din install
Originally Posted by Crazy4x4RT
Nice. Give us the details on the mounting and did you have to cut the trim?
the dash does need to be cut as it is only a din and a half opening... one thing i did have to do was on the back bottom of the ac controls there are metal tabs i had to grind them flat and as for mounting just used backstraps and mounted to the factory holes.... one thing i did notice is that the bottom of that radio opening is slightly angled but my dd has different angles for the screen that i can set with some more mods u can make it sit flat was just a lil lasy i think it looks ok in my truck! the dash was orig the wood grain but i painted everything back because i had to mod the dash.... looks better black any ways.
kenwood excelon dnx-8120
focal 165 kf components in front
jl audio vr 6.5 components in rear in stock location
kenwood excelon x600f 4 channel
kenwood excelon x1200m mono block
2 kenwood excelon xw1224d 12 inch subs in speced ported box
Old Dec 19, 2011 | 11:18 AM
  #284
DirtyHarry83's Avatar
DirtyHarry83
Here is my 94 Dakota
Side
Back
I recently added the 7pin connection. It's not a true 7 pin yet. I need to add Electric brake controller and the 20 amp line.
Front
Old Dec 19, 2011 | 11:29 AM
  #285
DirtyHarry83
I recently replaced the Head liner. I only took one picture because it was cold and I had limited time to finish the work. I do plan on banging out the dent in the right rear. I have some minor rust in the bottom of both front panels. It rusted through thanks to the person that owned it prior to myself. He parked it under a pine tree and never cleaned out under the hood cowl? Not sure what to call it but I cleaned it out 2 years ago (now I do it every spring.) and pulled 3 + LB's of dirt and pine needles. Tempted to put up some nylon screening under the cowl.
Old Dec 20, 2011 | 04:33 AM
  #286
maine express's Avatar
maine express
Default 1987 dakota
here is the link to my gallery pics i added of my 1987 dakota express https://dodgeforum.com/forum/members...ure33589-a.jpg
Old Dec 22, 2011 | 06:52 AM
  #287
89newbie's Avatar
89newbie
Where did you find the headliner? I pulled what was left of mine on the 94 and and bought 2 rolls of stuff to do the job because it matches the interior, but a form fit headliner would be great. Mrs. Newbie's 89 needs one also. Man the quality difference of the material is amaizing. The 94's was crap but the 89 is still great but sagging. Thanks for the help
Old Dec 22, 2011 | 08:42 AM
  #288
DirtyHarry83
The fiberglass foam board wasn't damaged on my truck, just the foam backed fabric. I got the foam backed fabric kit and it came with a can of adhesive. The old fabric came right off without issue. I took a soft brush to the old glue and left over foam. I also learned that when re applying glue, wait 4-5 minutes for it to setup otherwise you don't have a tacky surface for the material to adhere.
I got everything from
http://www.yourautotrim.com/
*Note the cans of adhesive are BIG. You shouldn't need two cans for 1 job. I probably have 1/3rd of the can left maybe more.
Sorry for any confusion. If your board is bad then I'd suggest checking out
http://www.jcwhitney.com/headliner-k...d412j1s21.jcwx .
Also you can go to a you pull it and see what's available.
Old Dec 24, 2011 | 09:38 AM
  #289
89newbie's Avatar
89newbie
ai'm going to have to take a closer look. When I took out the unglued rotten fabric all kind of black dust came down which I took to be mold. I bought a big can of 3M adheasive and I have the fabric but I will look at your sources don't want to do this twice.
Old Dec 29, 2011 | 03:47 AM
  #290
zirbs's Avatar
zirbs
whats different in this 91? first one right gets more pics.
