Roll call! Post up Pics!!!
Old Aug 10, 2012 | 08:53 PM
  #511
moparnut38's Avatar
moparnut38
Originally Posted by nemesis158
Im assuming it would have to be.
a standard cab + longbox dak has the same frame as an extended cab + shortbox, there isnt anything longer, and the front of the bed (right behind the cab) is where the extra length is.
i was just thinking about this the other day. having a longbed would be very nice......
the xtra length is yes as you said right behind the cab but it is also behind the rear wheel also as I have a set of fiberglass running boards for the short box and if I line up the wheel opening it also is longer in the back too. yes the frame has too be cut and lengthened about 20 inches or so and it has too be done right behind the cab and before the front spring perch for the rear springs. I have a pic with the body off and the frame bare ready for sandblasting
Old Aug 10, 2012 | 08:58 PM
  #512
moparnut38's Avatar
moparnut38
Smile
Originally Posted by Crazy4x4RT
I have always said that is exactly what I wanted to build one day. Once all painted it will look stock.
To me a truck is a truck, and the Bed is what makes a truck. The more hauling space from a long box is what is needed at times.
I would love to have a long box as yes that is better for the hauling. But I am thinking about painting it the same as the one I drive now and put a 440 big block into it with the sport tires and rimes and deck it out like the one I am driving now
Old Aug 10, 2012 | 09:06 PM
  #513
moparnut38's Avatar
moparnut38
Old Aug 10, 2012 | 09:55 PM
  #514
WRXCarl's Avatar
WRXCarl
EXT. Cab Long Box!!! Thats exactly what I want!! Want to make Me one
Old Aug 10, 2012 | 11:20 PM
  #515
Crazy4x4RT's Avatar
Crazy4x4RT
Is the frame just bolted? Or is it bolted and welded?
Old Aug 11, 2012 | 10:08 AM
  #516
moparnut38's Avatar
moparnut38
The frame is bolted and welded just to make sure it all says together with no problems. I know it might be overkill on bolting it but when this is the first real project like this and you dont know anyone to ask about doing something like this thats what ya get but yes I am doing all this in my storage unit that is 14 foot wide and 45 feet deep so when ya dont have the fancy tools too do anything with.
Old Aug 11, 2012 | 10:09 AM
  #517
moparnut38's Avatar
moparnut38
it took me a month of measuring to make sure I cut everything in the right spot
Old Aug 11, 2012 | 11:11 PM
  #518
moparnut38's Avatar
moparnut38
My first car show today with the Dakota and I took 2nd place in my class
Old Aug 11, 2012 | 11:53 PM
  #519
pinkfloydeffect's Avatar
pinkfloydeffect
Originally Posted by moparnut38
I have 4 sets of those wheels and my advise is go with the 15" ones as the ones on my truck are 14" and I had too shave the caliper down abot an 1/8" too make them work witch voids warrenty on the calipers.
Do you wana sell me a set then? Those in the photo are 14"!? The wheels that came on my Dakota were 14" were yours 15" from the factory? I planned on going with 15" wheels mine are too small.
I like the extended Dakota idea...I always wanted to take a regular cab long bed and cut the end of the bed off after the axle so the tailgate is RIGHT after the rear wheel (I think it would be the same as a regular cab with a 6.5ft bed only if you moved the axle and wheel well back).
Old Aug 12, 2012 | 08:28 AM
  #520
dobaroy's Avatar
dobaroy
The frame is bolted and welded just to make sure it all says together with no problems. I know it might be overkill on bolting it but when this is the first real project like this and you dont know anyone to ask about doing something like this thats what ya get but yes I am doing all this in my storage unit that is 14 foot wide and 45 feet deep .
Excellent job . . . bolting and welding was the only way to go. Tell us what you did about the driveshaft.
