need a fast responce... question about 9.25 axle swap
Old Nov 7, 2008 | 08:07 PM
95_318SLT's Avatar
95_318SLT
Default need a fast responce... question about 9.25 axle swap
I'm finally ready to tackle the swap tomorrow but I was just doing some measuring this evening and realized that the 9.25 differential carrier from the middle of the axle case to the end of the yoke is about 3 inches shorter than the 8.25. Did the couple of you who have already done the swap run into this problem and if so how did you take care of it. I was thinking it could possibly just be slid 3 inches up the leaf springs but i'm not sure. I hope the driveshaft won't have to be lengthened.
Old Nov 7, 2008 | 09:06 PM
Bad96_3.9's Avatar
Bad96_3.9
there is some play in the slip joint that will take care of it, that is why you will probably have o change the pinion angle on it. after the swap throw an angle finder in the d-shaft and see what the angle is.
Old Nov 7, 2008 | 09:35 PM
95_318SLT's Avatar
95_318SLT
What exactly are you refering to when you say the slip joint? Any chance you have a picture?
Old Nov 7, 2008 | 09:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
He is talking about the end of the driveshaft that slides onto to end of the transmission. This is a slip yoke. It can slip back and forth if needed. For bad96 this slip yoke was able to slip out enough to compensite for it.
Old Nov 7, 2008 | 09:59 PM
95_318SLT's Avatar
95_318SLT
Thanks
Old Nov 8, 2008 | 03:52 PM
Bad96_3.9's Avatar
Bad96_3.9
sorry, you cant tell what i is because i is covered up my the rubber accordian boot thing on the rear shaft.
