New Wheels
Old Jan 17, 2009 | 05:25 PM
  #21
Bad96_3.9's Avatar
Bad96_3.9
Originally Posted by DukeSupes
Bad96_3.9,
Are you saying that you have some of the newer style chrome rims and center caps or the older style?
the chrome 15" ones that came on 94-96 dakotas. they are in good shape and so are the centercaps.
Old Jan 21, 2009 | 10:45 PM
  #22
mikeyman0166's Avatar
mikeyman0166
So I gotta ask as I just found a set of stock 16" rims off an 01 and found a set of 265/75/16 tirs cheap,, where did you buy the T bar keys?, and how did you unload them,, did you rent a tool to do this?
Old Jan 21, 2009 | 11:01 PM
  #23
95_318SLT's Avatar
95_318SLT
http://www.totalperformanceonline.co...ayout_0100.xsl (It says lowering kit, but what they do is reindex the hex keys 30 deg from stock, so depending on what orientation you install them they will either advance the keys 30 deg or back them off 30 deg... Basically they'll work as either lift or lowering keys.)
I borrowed a torsion bar unloader from a mechanic friend of mine. With that tool the swap took about 15 min. I've heard some people say they swapped keys without the tool, but if you can find one it will make the job very easy.
As for how to unload them, the tool looks like a large C-Clamp that holds the keys as you back off the adjuster bolt. When you get the bolt off, you back off the unloader and the torsion bar should be completly unloaded before the unloader is done backing off.
I would suggest you get a body lift kit too for that size tire. I'm going to. Those tires just barley rub the inner fender well with the torsion bars all the way cranked.
Old Jan 22, 2009 | 06:07 AM
  #24
mikeyman0166
Do you think that 265/70/16's would have been a better choice as they are 1" smaller in diameter? Is the rub that you have now one most people could live with?
Old Jan 22, 2009 | 12:26 PM
  #25
95_318SLT's Avatar
95_318SLT
It all depends on how high you want your truck. 265/75R16's are 31.5" x 10.5". There are a few people on this forum with larger tires than that. If you just crank the bars and don't want to mess with a body lift you should probably go with 265/70R16. I'm gonna fix the rubbing problem by putting a body lift on my truck (although my frame is bent and the left tire rubs on the front crossmember at full lock), but it will at least fix it from rubbing on the fenders.
Old Jan 22, 2009 | 03:14 PM
  #26
DukeSupes's Avatar
DukeSupes
I just picked up my new wheels from off of a 00 durango. Same 15'' size as the current ones. I cant wait to get them on tonight!
Old Jan 22, 2009 | 03:21 PM
  #27
95_318SLT's Avatar
95_318SLT
Sweet, you'll have to get a picture up when you get them on.
Old Jan 22, 2009 | 07:38 PM
  #28
DukeSupes's Avatar
DukeSupes
So i took the new rims into the shop and had them switch the tires over. i was very happy with my recent purchases until i came home annd turned hard left to park in the garage and felt something grinding against something else!!!! i pulled out the trouble light and looked inside and there i could see the inside of the rim was rubbing against the tie rod end.... anybody know of any tricks around this? i am completely sick by this. it only rubs on the inside of the rim (not the bead part).
Old Jan 22, 2009 | 09:51 PM
  #29
Bad96_3.9's Avatar
Bad96_3.9
if it is just barely rubbing on the tie rod i would grind a little off the tie rod. i had to gring my control arms a little for the 17's.
Old Jan 23, 2009 | 12:59 AM
  #30
DukeSupes's Avatar
DukeSupes
I am taking the truck in saturday to have the balljoints replaced. I will ask ron if he can do somethung with it....is it possible to adjust tge power steering to stop turning just before the rims hits? seems like they hit just before hard over...so it wouldnt take much correct this??
