my poor ole besty needs sum help maybe fuel pump or filter maybe both take a look...
Old Jan 13, 2009 | 11:48 AM
DukeSupes's Avatar
DukeSupes
Rhodes,
DO NOT DROP THAT TANK! I recently replaced the fuel pump in my '93 and it was SOOOO much easier to take the bed off! Only 6, maybe 8 bolts hold it on the frame. And you can easily use some 2X4s to prop it up while you work. This is definitely a two man job and I did this with my dad so you should be in good shape if your dad is helping you. The bolts are fairly easy to find just look along the frame for bolt heads that are obviously bolted UP. Also, you will want to keep in mind that you will need to take the fuel filler tube loose from the bed before you start. Here are some pics of when I did mine.
https://dodgeforum.com/forum/1st-gen...fuel-pump.html
Old Jan 14, 2009 | 01:02 AM
xxxxrhodesxxxx's Avatar
xxxxrhodesxxxx
so if we drop the bed... would we still have to take of the tank straps..??? or just work from the top..? and thanks for the pics man dat really help my dad out hes ready for that damn tank now lolz..thank god for my pops.!!! hes an ******* all tha time but hes my ****a tho 4real al wayz savin my ***...il help contribute sum by posting so pics of the tank when its off.. and in side the tank too...and ill let yall know wat up saturday afternoon...!!!! later
Old Jan 14, 2009 | 01:03 AM
xxxxrhodesxxxx
oo just an fyi were gonna reaplace.the pump and filter if theres any filter down there we shall see...!!!
Old Jan 14, 2009 | 09:16 AM
DukeSupes's Avatar
DukeSupes
No dont worry about the tank straps. Just leave those where they are. Just lift that bed up at an angle so that you dont have to worry about the brake light wires just like in the photo.
Another thing that the post that I sent you talks about are the small plastic clips that hold the gas lines on the pump. They will break very easily because of age. That post gives you the part numer and where you can get replacements should you break any.
Old Jan 14, 2009 | 10:11 AM
xxxxrhodesxxxx
yeah we break em lol prolly replace everything down there the truck came from up north
so its got suface rust on the bottom not a whole lot but its there those "bolts" gunna be a ****....!!!!
Old Jan 14, 2009 | 01:38 PM
DukeSupes's Avatar
DukeSupes
Yeah, definitely take the time to spray down those bed bolts with a generous amount of WD-40.
Old Jan 14, 2009 | 04:03 PM
Dodge man Dan's Avatar
Dodge man Dan
take the bed off way easier. its 6 bolts and 2 guys verses lyin on ur back 4 hours!
