need help w/ heater core
Old Jan 18, 2009 | 12:43 PM
murdered93'kota's Avatar
murdered93'kota
Unhappy need help w/ heater core
i need to know where the bolts are that hold the heater/ac box in. manual just says remove bolts but doesnt tell me where they are. and also if the gauge cluster/upper dash needs to be removed for all of the heater/ac box to be removed
u could even call me and talk me thru it
248 462 3138
jeremy
thnx
Old Jan 18, 2009 | 05:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Most likly they are talking about the ones that are on the other side of the fireway, under the hood! There are more online manuals listed int the FAQ. Im not to sure if you have to remove the gauge cluster or not. A few others have fully removed it. Let me know how it goes. I have a vacuum leak somewhere back there.
Old Jan 19, 2009 | 08:37 PM
jdog's Avatar
jdog
it is just the bolts on the firewall that hold that in and when i did my heater core i just pulled the lower panel, ashtray and glovebox, when you pull it out you have to twist it to get it past the dash but it will fit also when you do this be sure to label all of the vacuum lines and electrical conectors
Old Jan 19, 2009 | 10:55 PM
JetNoise's Avatar
JetNoise
I have AllDATA for my truck and I copied some pics that may help you....
It seems that you do have to take out the "lower instrument panel module"
http://www.alldatadiy.com/alldata/AF...40371/42159654
The rest of the pic's are in order of how they are on the site... any other questions let me know....
http://www.alldatadiy.com/alldata/AF...70014/81869689
http://www.alldatadiy.com/alldata/AF...70014/81869690
http://www.alldatadiy.com/alldata/AF...70014/81869691
http://www.alldatadiy.com/alldata/AF...70014/81869692
http://www.alldatadiy.com/alldata/AF...70014/81869693
http://www.alldatadiy.com/alldata/AF...70014/81869694
Now I just hope these pics load for ya....
Old Jan 23, 2009 | 03:06 PM
pashadowops's Avatar
pashadowops
Maybe it's just me, but I think Alldata has their site protected cause when I click on these links, I get a different image every time and so far non of them have anything to do with removing the heater core.
Old Jan 25, 2009 | 10:48 PM
JetNoise's Avatar
JetNoise
Okay. I thought I'd try it... I figured if ALLDATA could help more than just me, it'd be worth it!
