interior lights, dash lights, and the radio
Old Jan 18, 2009 | 08:01 PM
lerch73's Avatar
lerch73
Default interior lights, dash lights, and the radio
i own a 1992 dakota. the interior lights ,dash lights,and the radio worked then i changed the battery and they quite working.what would cause this to happend?
Old Jan 18, 2009 | 08:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like you forgot to reconnect a wire to the battery. Also have your checked your Fuses! Check out the FAQ to find out a fuese diagram.
Old Jan 19, 2009 | 12:03 AM
codydakota's Avatar
codydakota
sounds to me like the 5amp fuse in the power distribution center popped, happened on my sis's truck, and it also happened after i changed the battery
Old Jan 19, 2009 | 11:03 AM
lerch73's Avatar
lerch73
i already checked all the fuses and they were all good
Old Jan 19, 2009 | 05:31 PM
dodgerules86's Avatar
dodgerules86
Check all your fuses again. (In the interior fuse block and under the hood). A visual inspection isn't always the best.
Get a multimeter out, remove each fuse, and test each fuse for continuity between each contact. Sometimes they "break" where it's hard to see.
All fuses, even the big "maxi" fuses.
99% sure it's a fuse problem.
Old Jan 19, 2009 | 05:51 PM
DukeSupes's Avatar
DukeSupes
Agreed, There is another fuse box just in front of the battery under the hood. Once you pop that cover off check the #5 fuses,(may only be one) and replace the one that is blown. I recently went through a fit like this and blew 4 before I found out what was blowing them....it was the hood light.
Old Jan 19, 2009 | 05:58 PM
dodgerules86
What caused mine to blow was the passenger side floor light. But it was totally my fault. I was doing some work, and didn't protect the live wire for the light (put electrical tape over it). Traveling down a country road, hit a bump, it contacted a ground, lost my radio and some lights
Old Jan 20, 2009 | 02:38 PM
lerch73's Avatar
lerch73
ok i will try that.
Old Jan 20, 2009 | 09:38 PM
lerch73's Avatar
lerch73
thank you . i got interior lights and the radio but still don't have dash lights.what would cause the dash lights to not work?
Old Jan 27, 2009 | 12:42 PM
DukeSupes's Avatar
DukeSupes
Yeah dash lights are not controled by that fuse. I believe that there is another fuse that must have blown. And I dont think that fuse is in the cab. If you pull the cover off of each of the boxes there is a diagram of what fuses link to what components. If nothing else, pull out your owners manual. It should tell you what all the fueses do. (Thats how I found the fuse for the radio and cab lights.)
