trans cooler question
Old Jan 18, 2009 | 10:09 PM
1st gen fan's Avatar
1st gen fan
Default trans cooler question
well for starters the forums here are great so much info here
i just bought a 92 4x4 dakota that has had a 4' body lift well it seems it wasn't done the correct way so the radiator was up and not secure and the fan got a hold of one of the trans cooler lines and made a mess its not fixable tho the radiator is fine i was going to buy a new one but everyone is telling me to just get a aftermarket trans cooler and it would do fine i was under the impression that it needs the trans cooler that is built in the radiator and a aftermarket trans cooler to do a good job i dont mind buying both just dont want to if i dont need too
Old Jan 19, 2009 | 12:02 AM
codydakota's Avatar
codydakota
If the radiator is fine the internal trans cooler should be fine also, however you can get a trans cooler fairly cheap and plug the trans into that instead. You don't NEED a second trans cooler, but I recommend it to keep your tranny from getting too hot, especially when towing or hot rodding. '92 and '93 transmissions are hard to come by for the 4wd's if yours goes out, just to let you know, I'm having this difficulty with my '92 4x4. '91 and earlier will not work and nor will a '94/'95/'96. So whatever you can do to keep it from quitting on you, do it.
Old Jan 19, 2009 | 12:10 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It deffently is better to have both types of coolers. But if needed the non radiator one would work. Bud if you carry heavy loads or driving hard or uphills, or towing. You need that extra cooler to keep the trans from burning up. Accully 92-96 are the same according to autozone.com
Old Jan 19, 2009 | 02:59 PM
1st gen fan
well got ahold of my brother today and he works for a auto parts distributor here in town so he can get parts at cost and can get me a new radiator for almost the same price as a trans cooler thanks for all the quick reply's
Old Jan 19, 2009 | 10:29 PM
Bad96_3.9's Avatar
Bad96_3.9
i would run both coolers, run the aftermarket in the return line to the tranny after the stock cooler. and a 4 inch body lift sounds unsafe to me........lol.
