Hello from Missouri!
Old Feb 15, 2009 | 03:18 PM
  #21
gatlin04's Avatar
gatlin04
anyone?
Old Feb 15, 2009 | 03:56 PM
  #22
Crazy4x4RT's Avatar
Crazy4x4RT
The fuel pressure regulator regulates the fuel pressure. On 92-93 it is on the fuel rail driver side rear. On 94-up it is located on the fuel sending unit that is inside the fuel tank.
Old Feb 15, 2009 | 11:11 PM
  #23
gatlin04's Avatar
gatlin04
Update....
I think that ive figured out what is wrong.
I turned the ignition on and then tapped the computer. I heard the fuel pump kick on, so i turned it over and then it started right up. I drove it for awhile and then it died. I poped the hood and tapped the computer again.... it started right up again!
Later on in the day, I was able to drive the truck to my house (about 45 min away) with no problem.
Hopefully it is just some kind of bad ground rather than replacing the entire computer.
Does anyone know if there is any troublesome spots in respect to the computer?
Thanks in advance!
Old Feb 15, 2009 | 11:25 PM
  #24
Frenchy's Avatar
Frenchy
To learn the ins...
Open the door, and stare deliberately at EVERYTHING...
To learn the outs...
Go outside, and do what I stated to learn the ins...
