V10 swap?
Old Feb 2, 2009 | 03:58 PM
jibs1723's Avatar
jibs1723
Default V10 swap?
has anyone attempted to swap an old 8.0L V10 into a dakota. i have a 96 dakota with the 5.2 auto. its got almost 140,000 and still runs good but i really don't like the trans. at highway speeds it will randomly downshift out of overdrive and will not go back in for a while, even if i slow down let of the gas nothing. So i was thinking of trying to put a V10 5 speed in it. i know that the v10 is approx 4 inches longer than the small block and was wondering if anyone has attempted this. Thanks
Old Feb 2, 2009 | 04:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The truck v10 will be (as far as I know) is the same exteriorliy the same as the viper v10. For 1st gen I havnt seen any with viper engines. But you could be the first. The closest would be gen 2. Here are a few post of it. You can do a search to get lots more info.
https://dodgeforum.com/forum/2nd-gen...this-swap.html
https://dodgeforum.com/forum/2nd-gen...t-10-swap.html
https://dodgeforum.com/forum/dodge-d...otor-swap.html
https://dodgeforum.com/forum/2nd-gen...otor-swap.html
Old Feb 2, 2009 | 05:04 PM
daksport91's Avatar
daksport91
do it, that would be insane! I expect a build thread haha .... the only thing id really be concerned about is the length of it, it will probably be a tight fit......Correct me if im wrong but didnt the older dakota shelby's that had the 318 use electric fans because a clutch fan system wouldnt fit and in 91 they changed something so it would fit. Although if that is the case it really is only 2 inch's... skinny little electric fans would fix that
Old Feb 2, 2009 | 06:23 PM
codydakota's Avatar
codydakota
The frame would need some beefing up just for the torque alone, but it's possible. Length would be a problem, but you could always get around that with an e-fan setup
Old Feb 5, 2009 | 06:49 PM
Bad96_3.9's Avatar
Bad96_3.9
i really dont thing it would be worth the money, but i am an anti v-10 person, they sound retarded. it would take some serious fab work and dollas too. but like others have said, no one else has done it to a 1st gen, it would be a show stopper i done right!
Old Feb 6, 2009 | 12:35 AM
1shotjake's Avatar
1shotjake
wonder what a mopar v12 would sound like if they did what they did with v10's... just add 2 cylinders. man that'd be like a 10l
then again, it might not sound like a mopar at all, they'd prolly just steal a 6.0l from the AMG plant XD
