1990 Dakota hesitation/sputtering problems??????
Just bought a 90' Dakota I have replaced the fuel pump, IAC, TPS, catylic converter, plugs, wires, cap and rotor. The truck starts up and idles fine, but when you give is gas it like falls on its face. If I hold the pedal to the floor the motor just boggs then it will stall. Its like its getting too much fuel or something. I checked the fuel pressure and its at 14.5 psi. Anybody have any advice????
Yeah, just leave the battery disconnected for 10-15 min. It won't run well at all at first when the computer resets but that's because it needs to re-collect the info from the different sensors and then decide what to do with it... so after you reset it try to drive it for 20-30 min on the highway if you can.
That's what caused my problem I got one at Auto Zone worked OK for a few days then started doing what you describe. I then took it to the dealer and they fixed it, bad water temp sensor the one i put in from Auto Zone.........
Trending Topics
Ok.... Just replaced the water temp sensor, and disconnected the battery for 30 min. The truck still runs like crap. Its seemed to run alittle better when the engine was hot, the gauge was reading 3/4 to the hot side. Anyhow, do yous think it could be a dirty injector??? Because when I barely push the pedal it will rev great, but when I push it further than that it just boggs down. It seems like it might not be getting enough fuel?
thanks
thanks
