Before and After
Old Mar 30, 2009 | 11:26 AM
91odsami's Avatar
91odsami
Default well its coming along
Decided I've been lingering and bugging you guys long enough and i should put some pics up. They go from when i got it to how i drove it for the winter and a few pics of the new tires and rear axle. still need to get the front one but its in a garage that has not been shoveled all year soo it will be a little while. the bumper was straight when i put it on but pulling out a 3/4 ton dodge and the chain came off the frame and caught it
Old May 12, 2009 | 04:43 AM
ModT's Avatar
ModT
Old May 18, 2009 | 01:43 PM
Hahns5.2's Avatar
Hahns5.2
Before
As of now
I'm jealous of your bucket seats 95_318SLT!
Old May 18, 2009 | 01:52 PM
95_318SLT's Avatar
95_318SLT
Thanks! I lucked out getting a truck with those! I could be wrong, but they don't seem very common. I wouldn't mind having that hurst shifter of yours!!! Did you put that in or did the truck already have it when you got it? (if you put it in, did you notice any difference in shifting speed, smoothness, etc?)
I'm glad you took off that bug shield and camper shell. It looks a lot better without!
Old May 18, 2009 | 02:00 PM
Hahns5.2's Avatar
Hahns5.2
I just put the Hurst in a couple days ago. Shorter throws and a lot less slop. Only problem I had is that I bought it used, and in 2nd gen trucks the dash changed somewhere around 2001 so it needs a 1/4" spacer between the shift tower and tranny, since the spacer was RTV'd on I installed it with it, everything was fine till I went to the drag strip Saturday night and kept missing my 1-2 shift. It turns out the shift "Ball" was able to pop out of the "Cup" for the shift rails in the tranny when you push the stick over hard enough because of how the spacer lifts up the shifter, and since I was being pretty aggressive with my shifts (barking tires on my 2-3 shift ) it was popping out. So the next day I removed the spacer and it's fine now. It does transfer more noise into the cabin since it's not rubber isolated as well as the stock shifters are.
Old May 18, 2009 | 03:32 PM
95_318SLT's Avatar
95_318SLT
Sweet! Even the stock shifter transfers a good amount of noise! I noticed a huge difference in noise when I went from the auto to the 5 speed. I'd love to get one of those shifters but I have so many other projects going on with that truck that it's gonna have to wait a long time.
Old May 22, 2009 | 08:05 PM
grtrat1's Avatar
grtrat1
Before.. Bought it for $300
Removing rusted cab
|New cab
After... Not 100% complete yet...
Old May 22, 2009 | 08:54 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Thats a good one! What else did you do beside remove rust and paint. Why was the dash torn apart? Or was it all to remove rust?
Old May 22, 2009 | 08:56 PM
grtrat1's Avatar
grtrat1
Every body panel was replaced... i bought another cab and the guy gave me the bed... The original fenders and doors were all dented up, so I used the ones from my 90 dakota..The cabs were 2 different years, so I had ti use the original dash..
Old Jun 22, 2009 | 09:33 PM
dakota33's Avatar
dakota33
well thought I should share mine.. first pics of the tear down, and body work.. then last is lift.
tear down
after paint.
out of shop , new rims.
LIFT
