trans swap help please
Old Feb 12, 2009 | 05:02 AM
smokey68dart's Avatar
smokey68dart
Default trans swap help please
i need to know what all i would need to put the 5spd from a 93 dakota 4x4 into my 91 dak 4x4 i know i need the trans and the bellhousing would i need any other parts??? thanks smokey
Old Feb 12, 2009 | 12:32 PM
kahanabob's Avatar
kahanabob
Whats in the 91 now? stick or auto.
Old Feb 12, 2009 | 03:48 PM
smokey68dart
it is a A535 5speed manual and im wanting to put in an ax15 5 speed manual
Old Feb 12, 2009 | 05:38 PM
mikeinoregon's Avatar
mikeinoregon
I think the trans and bellhousing would cover it, unless for some reason you needed a new pressure plate or something. I've got a copy of the '91 FSM, if you need anything from it, let me know and I'll try to get it scanned for ya.
Old Feb 16, 2009 | 02:47 AM
smokey68dart
any one eles know if all i will need is the bellhousing and transmission and the 93 is a stronger trans correct
Old Feb 16, 2009 | 01:39 PM
mikeinoregon
I think the '93 trans is stronger than the '91 trans. One other thing to measure would be the driveline. Over on Dak-Dur, a fellow with a '91 swapped in a '93 tranny and had to have a new driveline made. His, however, is a lowered 2wd.
Old Feb 18, 2009 | 04:15 AM
smokey68dart
anyone know if the mach speedo will interchange with the elec one on the 93 i beleave that the 93 uses a speed senser not a cable
Old Feb 18, 2009 | 11:19 AM
Crazy4x4RT's Avatar
Crazy4x4RT
They will interchange with no problem just remove the sensor and housing that is bolted on the side of the tranny and gear and install the Pieces exactly how you take it off.
Old Feb 27, 2010 | 10:39 PM
yourconfusedhaha's Avatar
yourconfusedhaha
anyone know if this worked?
